Thanks Mike for the compliments and the drool thats on the Gwangi is from 5 minute clear exposy and on the Curse of the Demon bighead that is clear styrene scraps stretch out from being heated and then glued on to the desired location of the bust or kit and then take 5 min exposy and go over that to make it look like actual drool and then color it with what ever clear paint you want to use.WOW Dan!! This is perfection! Awesome build, and paint!:thumbsup::thumbsup::thumbsup:
Cool looking bloody drool! I've never had much success making drool at all, what do you use for that?
Mike :wave:
Thanks for the great tip Dan!Thanks Mike for the compliments and the drool thats on the Gwangi is from 5 minute clear exposy and on the Curse of the Demon bighead that is clear styrene scraps stretch out from being heated and then glued on to the desired location of the bust or kit and then take 5 min exposy and go over that to make it look like actual drool and then color it with what ever clear paint you want to use.
I would need alot of metal to make that cage:freak:. Plus were can one get a nasty little man to put on that cage if it was made?Simon its a Big kit and bigger than thought it was:freak:!are you going to put it in a scale cage with the nasty dwarf climbing the ladder???
Thanks a million Sean for the complimentsLove the paint job you did here, Dan. It's richly layered and well done.
Sean
HOW BIG is it? Looks about 14-16" high. I'd use PVC tube instead of metal though.I would need alot of metal to make that cage:freak:. Plus were can one get a nasty little man to put on that cage if it was made?Simon its a Big kit and bigger than thought it was:freak:!
