What is the best spray paint for the U.S.S. Enterprise outer hull?
My question was genuine, though as I admitted in the first sentence, you do want to make sure which version you are talking about, even among the TOS Enterprises.Chuck is right- this is straying into "voodoo" territory. Not only is there no one right answer, but the beliefs are strongly held- so "peace". There are some dedicated threads on every version, so perhaps scan those. You will get advice and detail like water from a firehose. So enjoy!
Someone around here posted a link once that allowed you to convert a sampled JPEG into the closest available Tamiya color.I never thought the 11-foot and three-foot models were the same color, but I've been told they were.
What I'm having a hard time getting at is- what would be the most universally acceptable and historically accurate spray paint to use on TOS starships, specifically in regard to the TOS 1/350 model, to resemble the 11-foot production version, prior to its arrival at the Smithsonian?
Can someone repost that?
As to your question:
So do you want it to have the same shade of grey as the filming miniature,
or appear lighter as seen on screen?
If you see the filming miniature in person, the original color is a lot darker then I've seen it conveyed in any photos, probably due to the fact that like the heavy lights involved in filming it from TV, simple camera flashes make it look much lighter then in person.Same shade as the filming miniature, but maybe with a slight blue rather than a slight green.
Both models were painted with the same colors during (roughly) the same periods. The 33 inch Enterprise wasn't altered for the second pilot, but then again neither was the overall paint job on the 11 foot model. The 33 inch model was modified about the same time as the 11 foot model for the series and was intended to reflect the changes (similar window patterns and decals), but it wasn't clear at the time if it was going to be put in front of the cameras again for effects footage. The main reasoning for the changes was to use it in publicity photos.Especially I'm interested in the coloring of the three footer and if and how it varied.
Thank you Shaw. I've ordered some Tamiya AS-5 Luftwaffe Blue, and am confident I'll be pleased. Thanks again!Both models were painted with the same colors during (roughly) the same periods. The 33 inch Enterprise wasn't altered for the second pilot, but then again neither was the overall paint job on the 11 foot model. The 33 inch model was modified about the same time as the 11 foot model for the series and was intended to reflect the changes (similar window patterns and decals), but it wasn't clear at the time if it was going to be put in front of the cameras again for effects footage. The main reasoning for the changes was to use it in publicity photos.
Under studio lights with the actors, the hull color seems pretty light... but in it's last appearance as an effects model it seems as dark as the 11 foot model.
But here is the thing, when Star Trek Phase II was in production, it was the main reference source for the new Enterprise... including the color. So if you are wondering what the color would have looked like in normal photos, this shot should give you an idea.
Now, when I shoot my models, I avoid using the flash and tend to use defused light sources. But here is a comparison of my paint test using a flash (straight from the camera) with the 33 inch Enterprise in studio lighting with Shatner...
This is why I'm just fine with the color I picked. It works very much like the original color under similar conditions, and in my case I'm more interested in how these models looked in person (as real artifacts) rather than how they looked on screen (representing a fictional starship).
http://scalemodeldb.com/paint
I think this is what you are referring to.
I use it a lot to cross-reference paints and you can use a pic to find a color.
Logical and helpful, as always!Both models were painted with the same colors during (roughly) the same periods. The 33 inch Enterprise wasn't altered for the second pilot, but then again neither was the overall paint job on the 11 foot model. The 33 inch model was modified about the same time as the 11 foot model for the series and was intended to reflect the changes (similar window patterns and decals), but it wasn't clear at the time if it was going to be put in front of the cameras again for effects footage. The main reasoning for the changes was to use it in publicity photos.
