This has been completed for a while and I wanted to get this posted before the Deluxe kit comes out.
The Project:
Over the last few years I've found myself wanting to customize almost everything I build. The Broadway Dracula was no exception especially because of how many options it presented. Moebius gave us a beautifully theatrical scene and I thought it deserved to be done up in style. Here is the short list of custom mods I included included in the build. (Note: If you prefer visuals you may want to skip down to the video links at the bottom.)
Head- Mounted with neodymium magnets so that Mr Lugosi could pose any way he wanted.
Magnets are located in the base of the head/neck and in an armature I made for the upper chest.
http://i876.photobucket.com/albums/...way/Moebius Bela on Broadway WIP/P1030980.jpg
http://i876.photobucket.com/albums/...way/Moebius Bela on Broadway WIP/P1040019.jpg
Base- First I added a basswood plaque for the stage floor. Second, Aves Apoxy Sculpt was added to the edges of the stone walls to enhance their texture. This was done by using a rubber 'stamp' made from Amazing mold putty. I made an impression of one of the stones in the front wall in the AMP and then used it to press against the Aves while it was still soft. I was pretty happy with the results but would like to find a less costly material to use instead of the Aves which I like to reserve for more detailed sculpting.
http://i876.photobucket.com/albums/...way/Moebius Bela on Broadway WIP/P1030958.jpg
http://i876.photobucket.com/albums/...way/Moebius Bela on Broadway WIP/P1030960.jpg
Torch – A custom flame was created to add the look or fire to the torch. The torch flame was sculpted, molded and then cast in clear epoxy resin. I used two 'flickering' led's to enhance the look of the flame. The name plate was accomplished in a similar way.
http://i876.photobucket.com/albums/ab324/Spockr/Bela on Broadway/IMG_5532.jpg
A resin Gargoyle that I picked up on the bay was added to the model base to take up the void Moebius left for the soon to be released Deluxe kit.
http://i876.photobucket.com/albums/ab324/Spockr/Bela on Broadway/P1040308.jpg
I made four custom foot-lights and added them to the sub-base to simulate stage lighting. A flickering foot-light was placed behind the nameplate to provide 'extended toch light' for Dracula's face. I also made one red and two warm white footlights to light up the Gargoyle and to brighten/enhance the scene. They are mounted to a base that rotates and pivots. To view them please see the video links.
Power – The lighting power comes from two switched battery pack which mount with hook/loop tape on the rear of the wall.
Videos:
To see it in action -
For more info about the build -
I know this post was a bit long but the project was pretty big. I appreciate you taking the time to check it out.
Your comments, advice and opinions are welcome. How did I do?
Thanks for stopping,
MattL
The Project:
Videos:
MattL
