I am looking to run Ni-MH battery in my car and was wondering
what should I look for in mAh numbers. Also should they be matched
cells ie: team pack etc. or does it make a difference.
Where can I buy these.
Thanks
as you are not using them to actually propel the car like a pan car, a matched set is not going make a difference. but it will make a difference in how long it will be before having to buying a new pack or replacing dead cell.
as you charge and discharge them , if they are matched you won't have some cells over charged and some not fully charged. and same goes for if you discharge your pack . some cells may discharge too much and some not completely. this is the only reason i try to get a matched set. don't reallly care what the numbers are that much , just as long as its matched.
you could buy a cheap unmatched pack every year and not ever have a problem. but if you plan on using the pack for several years , your taking a chance. i have matched set that i've been using for 3years. but i have to do some extra work to make sure they stay that way. not a big deal but i've already said to myself that when they go im just going to buy some cheap ones every spring and not worry about it. either is fine just as long as you know what you have and do what is nessary after making that choice.
hope this helps. by the way i use 3800 s and sometimes i top off before the main. it depends on how much practice i've done and if i didn't make the A and may be bumping up and running several races.
