I have a Craftsman push mower with a b and s 6 hp. Last 2 times or so when using it it runs good for a while about 20 mins and then strats to die and does. It is hard to start if it does. I have gas in the carb bowl and when runs it is fine.What can i do and thanks
Try loosening/remove the fuel cap when it starts to die, it sounds like the cap is not venting properly. Have a good one. Geo
Discussion Starter · #4 ·
I did loosen the gas cap and still died.I did take the cap off and finished mowing though after i got it started. I talked to a guy and he said something about a wire could be damaged and/or the coil i think it was. He said that happens when the coil is bad
