1 - 1 of 1 Posts
Similar to the RC10B4.1 combo released yesterday, the RC10T4.1 Brushless NiMH combo features many of the components from the RC10T4 Team Kit while incorporating a 2.4 GHz 3-channel radio system, Reedy 3300kV brushless motor, XP SC4500-BL electronic speed control, Reedy 3000mAh WolfPack battery, and a wall charger. Additional upgrades can be made to your brushless RC10B4.1 using a full line of Factory Team B4 hop-ups, as well as Reedy and LRP performance parts.
RC10T4.1 RTR NiMH Combo Features:
- Built on the 7-time World Champion RC10T4 platform
- XP 2.4Ghz radio system (Requires 8 AA batteries)
- Reedy 3000mAh WolfPack battery (#694)
- XP SC450-BL Brushless electronic speed control with LiPo cutoff, forward and reverse with reverse lock out
- Reedy 3300kV brushless motor
- 2.6:1 ratio gearbox with sealed gear differential, dual-sided adjustable slipper clutch, and rubber sealed ball bearings
- Molded composite low-CG chassis with set-screw antenna tube lock
- Blue aluminum shock bodies with molded pre-load clips
- Battery strap with twist-lock thumb knobs
- Rugged steel turnbuckles for adjustable camber and front toe-in
- Pre-mounted tires on white dish wheels
- Factory finished Interceptor-T polycarbonate body
- Wall charger
Source: Associated [teamassociated.com]
More...
1 - 1 of 1 Posts
