The RC10B44 is a proven winning platform with two IFMAR World Championships and four ROAR National titles under its belt. The B44.2 Factory Team kit takes the next step in drawing out every opportunity to maximize the 4WD buggy’s potential. The big news on the B44.2 is the new Factory Team 12mm ‘Big Bore’ hard-anodized shocks. The shocks feature threaded collars, machined aluminium shock caps with bleed screws, and are completed with TiN “Gold” 3mm shock shafts. The end result is a 12mm shock that delivers a plush and compliant ride that keeps the B44.2′s tires planted on the ground.
The B44.2 also received an updated 2.5mm carbon-fiber chassis that is 8mm longer and 3mm narrower than the previous model. This not only improves stability and overall handling of the B44.2 but also accommodates the new LiPo quick-change battery mounting system, and VTS multiplate slipper assembly. The engineers in Area 51 have once again evolved the B44 to keep it a winner, while everyone else is just trying to keep up. If you’re ready to step up your 4WD program, the B44.2 is ready for you.
RC10B44.2 Factory Team Kit Features:
- Factory Team 12mm ‘Big Bore’ hard anodized aluminium threaded shocks with TiN “Gold” 3mm shock shafts
- Updated 2.5mm carbon-fiber chassis +8mm optimized for LiPo saddle packs
- VTS slipper (variable torque, multi-plate slipper with 3 drive surfaces) assembly featuring a high-rate spring
- Composite battery trays allow for battery position adjustment with integrated spacers and quick-change battery straps
- Updated 3.5mm front shock tower and 3.0mm rear shock tower designed specifically for the new 12mm shocks
- Factory Team 12mm aluminium rear clamping hexes and rear hex wheels
- Updated front top deck for increased rigidity featuring locking antenna mount
- Factory Team 7075-T6 blue aluminium 0° rear hubs with oversized outer bearing
- Updated front suspension arm for increased durability
- Blue aluminium cam-type motor mount for easier and more secure gear mesh adjustments
- JConcepts Finnisher +8mm body (clear) and Factory Team protective chassis tape included
Source: Associated [teamassociated.com]
More...
