I have an old ariens s-420 snowblower. I think that it has a 4 hp tec. motor on it. I took the carb off and cleaned it and made sure the float and bowl were cleaned and working. I can get gas through the line and into the bowl when I take the bowl off and see gas running through. When I try to prime, I can feel the vacum but when I put the primer hose on the carb I can't see any gas shooting into the carb and it won't start. When I put gas into the cab it will run till it runs out of what i put into it. I am assuming that there is a primer type issue because it will run when i put gas into the bowl. Its almost like I can't get gas into the bowl. and the prime seems to work up to the carb.Is there some kind of diaphram inside the carb for the primer that might have gone bad?
Any suggestions or places to start looking would be appreciated, I'm running out of ideas and am starting to go crazy.
Thanks
Thanks
