1 - 1 of 1 Posts
ARC have released two new option parts for their R10 touring car. First up is a new suspension bracket which provides +0.5 angle for the suspension arm. Made by 7075-T6 aluminium it can be use in the rear/front to make the rear toe-in 2.5 degrees or in the front/rear and move the #1 suspension bracket to the front/front to reduce the front track width. Also new is a rear drive shaft made from hard coated 7075-T6 aluminium. It directly replaces the standard rear spring steel drive shaft and is 30% lighter than the original making for a more efficient transmission.
Source: ARC [arc-rc.com.tw]
More...
1 - 1 of 1 Posts
