1 - 17 of 17 Posts
I have this car body and would like any suggestions on wheel choice? They must be some type of custom wheels. As you can see in the pics RRR wheels are pretty big and the body will sit higher than I would like! Standard T-jet wheels sit nicely inside the wheel wells, guards, fenders, whatever you guys call them?? Will RRR narrows work????? Any other custom T-jet sized wheels out there??? Chrome would be good!
Discussion Starter · #6 ·
Thanks guys. Will order some wheels. These Ford Falcons were our answer to your Ford Mustang. The Falcons are a very sort after car now. And had great success "back in the day" on the race track. Can't wait to have a couple of HO Falcon racers.
· Model Murdering
Sadly... not really Dave.
3R wheels are 1/64 no matter how many ya cram, shim or shave on.
Some guys get away with using machined alumminum fronts. You know...the snazzy slot dish ...and the boring old ten hole centerline. (cant think of the guys name). I've found them to be rather delicate and meatless in the hub area...coincidentally right where they need the most chub for some thread bite on the axle.
I've polished up and used the old aluminum cigar box wheels. Naturally they are a press on affair and they wont hold a tire under duress unless you glue and true them. I rekon a guy could easily thread them to fit the 80 count axle. By shaving the back face of the ciggy rim (there's some excess) and taking a few strokes off the nut ya just might get it all packed in there.
Edit: Had to go spelunking for this pic ...LOL! One of my early restos from the before time with the aluminum ciggy rims pressed on.
BTW: Dont forget that MEV provides smaller style plastic rim in a rainbow of colors as well.
· LED Burner Outer
That puts things in a whole different perspective!! Looking at the Falcon I was seeing it more of a full sized car like the Torino. Was the Falcon that small and just had big car styling, or was it more of a full sized Torino size?? I'm cornfused!! :freak:
The size can be seen with these specs:
* Length: 4808mm (189.3in)
* Width: 1969mm (77.5in)
* Height: 1369mm (51.9in)
* Wheelbase: 2819mm (111.0in)
* Front Track: 1524mm (60.0in)
* Rear Track: 1524mm (60.0in)
* Weight: 1587kg (3500lb)
* Turning Circle: 12.0m (39.4ft)
* Fuel Tank: 79.6lt (17.5gl) 122.9lt (27.0gl) (Optional)
* Seating: 5
From http://www.uniquecarsandparts.com.au/ford_falcon_xa_gt_coupe_technical_specifications.htm
The Cobra II from the USA
Wheelbase, inches: 96.2
Length, inches: 175.0
Curb-weight range, pounds: 2,620-2,886 (1974); 2,646-2,751 (1978)
Width, inches: 70.2
according to http://auto.howstuffworks.com/1974-1975-1976-1977-1978-ford-mustang-specifications.htm
· Slotcar Fanatic
I thought the same when looking at the front end. Looked like they took the hood from the 73 Mach1 and grafted it to a Torino Talledega front end. The lines on the rear reminded me of the mid 70's Gran Torino. Anyway, not a bad looker. I would have considered buying one back in the day if they were available here in the States. :rolleyes: rr
1 - 17 of 17 Posts
