The key to using a terminal track is you must cut the common connection so that you can wire all four rails individually. Once all four rails have their own "metal strip", you can wire it any way you desire.Using the power tap methods of soldering or hooking the rails would be easier for positive track polarity which is driver's side rail in direction of travel.
Will using the terminal track tabs cause a negative wired track if the power
tabs are on the passenger side?
Joe
