Hello, new here and new to lawnmower problems.
A friend of mine gave me a Honda Lawnmower (HRT216-KS3A) stating it would only run on choke. That it did; as soon as you open the choke it races away and stalls 15sec after.
Thinking it's not getting enough fuel, I reproduced this failure mode with the fuel shut-off valve removed and the gas cap off.
Sprayed some Carb Cleaner on the Carb and around it (while it was running), but did not detect a major air leak.
Took the carb off and cleaned it in Mineral Spirit in the Ultrasonic Cleaner.
Put everything back together (with the gaskets alligned properly) and still the same result.
So, am I missing something?
If not, I guess I should try to buy a new carb; but which one and from where?
Engine #: GJAEA-1049087 MY1
Carb #: BB62BDPA18
Appreciate any help/hints.
Mike
Carb #: BB62BDPA18
Mike
