amp-dropping light bulbs????
1 reading
1.4K views 6 replies 4 participants last post by  k1m
#1 ·
Hey everyone....
I heard that BRP makes a device which utilizes ligfht bulbs to reduce charge current to allow smaller cells to be charged from a sub-c, 4amp charger.
Could someone describe the wiring? I'm trying to help a friend get his micro airplane flying, and he's on a tight budget, so I'm thinking of using the lightbulb method to allow use of an old charger I have.
I would just buy a BRP unit (and support a great sponsor) but I need to get an even greater current drop, since we are charging 270 mah nicads, not 600 mah AA's
Does this lightbulb device work w/ peak chargers?
could you do the same thing using resistors??
Thanks in advance for any info.....
#7 ·
rcnerd said:
is it a 1157 automotive bulb(s)?? just one?
is it in series or paralel?
does it 'confuse' peak chargers?
thanks!
The bulbs are acting like resistors. I believe if you put the bulbs in series with the battery you will lower the voltage to the cells. If you put the bulbs in parallel with the battery you will increase the current draw on the charger. If the charger only puts out 4 amps and the bulbs take 2 amps, I would think the battery would be charging at the remaining 2 amps. What effect that has on the peak detection circuit of the charger depends on how it's designed.
:confused:
The best way it would seem to me would be to experiment with a trickle charger and keep track of how long it takes it to get the cells warm. That's how most low mah cells are charged.
