Actually, I was preparing to spray Future (which I have done successfully several times before).
Thanks, Starseeker. I will break it down again and see what I can find.
Don't know if you're doing this already or not, but before spraying Future (or any acrylic paint for that matter), spray a little Windex through the brush first, blow it dry, and then immediately after being done spray a couple of tablespoons more, making sure you "backblow" some as described above. Then repeat the process with water. It's important to clean it immediately after being done, every time, and at the highest PSI setting.
I don't think anyone else touched on this, another thing you should do is keep the needle lubricated (I use Superlube). This more than anything will prevent tip dry, probably the most common cause of irregular spraying and clogging. I lube mine every couple of sessions.
As mentioned, be very sure you DO NOT soak anything that's not metal in the airbrush in lacquer thinner. I'm fairly sure the Paasche VLS doesn't have teflon parts (check the specs on Paasche's website or the manual if unsure)...teflon resists degradation by solvents, one of the main reasons I got an Iwata Eclipse CS. Even so, teflon is solvent
resistant, not solvent
proof...continued soaking in lacquer thinner
will damage teflon parts over time.
I made this mistake with my Iwata that has a rubber(?) o-ring in the piston assembly (that I
thought was teflon) and it swelled up and caused "trigger stick", requiring a replacement ($6 for a tiny little rubber ring).
Although opinions vary, it's really not necessary (or advisable) to use lacquer thinner to clear out the brush after every session, unless you're using solvent-based paint (that from the folks over at Coast Airbrush). Windex works great for cleaning after using acryls. If you have to use lacquer thinner, wear a respirator and make sure you have adequate ventilation.
I have a VL too, and I rarely use it anymore since I got the Iwata...much better airbrush, easier to use, and cleanup is simpler.
