hey tuners i,ve been playin with afx pan cars recently and noticed that the clustergear area seems to be a weak spot in the drivetrain. if you look at some you have it seems the cluster combo on most kinda floats and moves around on the shaft/rivette. i did see some of the old racer pans have replaced that shaft with a nut n bolt maybe a thin spacer too. i don,t for sure. has anybody tried this mod ? what size hardware is used and does it work good or just hunt for n.o.s. plate? check the pic and you,ll see this build will have a hotrod yellowjacket arm and beefy mags. witch translates to alot of power going to the rear wheels. i,m just trying to head off any gear slip and getting the power to the rears. anybody know bout this trik? thanx joe g
