1 - 2 of 2 Posts
All,
After completing my first little custom, I got to wondering how people go about swapping axles on the metal base cars. How do you pop that axle out w/o bending it? Any help would be most appreciated!
Thanks
Franky
Here You Go...From Swifty' Garage "Customizing Tips"
Posted: Apr 13 2007, 10:14 PM
Microcar
Group: Members
Rating: < 0 (
0 ) 3 >
WOW! It's been some time since this thread has had anything added.
Let me try to offer some tips to axel removal, and axel repair/replacement...
It is often asked by experienced and novice customizers " How do I remove the axels/wheels from the base (metal) of a casting? Those little metal "axel holdowns" can be a real pain,unless you have found simple ways to remove them...I prefer the following DREMEL bits to grind them out/off & release the axels in one piece (set). Here are the bits I reccomend...
They will grind thru the holddowns and release the axels, if you happen to go a little to deep, you can use a length of tubing (brass in this pic) to super glue the ends back in, and repair the axel.
Attached Image (Click thumbnail to expand)
Jeff Fleetwood/aka/DR.DREMEL
1 - 2 of 2 Posts
