1 - 20 of 128 Posts
A few photos of the new 8 window seaview kit... Wow this is a must have for the Seaview builders and fans alike... Frank, Dave & Gary have knocked this one out of the park... I am woking on a few build ups for clients and will be showing some photos along the way. Thanks Moebius!!!:thumbsup:
Question I have on the build lighting there is a difference between the TV to movie the movie version dose not show that nave lights in the sail were used like in the TV version and the Dead Lights are never shown lit up. what more could there be and keeping true with movie ? I have built both kits and lit both the TV version with Voodoo light set the newest one from scratch to give the move look i used 3 mm yellow in the bow a 5 mm bright in the bow searchlight 1 3 mm white over the conference table and 2 3 mm bright white on the tail fins
Discussion Starter · #8 ·
I agree... no Nav lights on the sail, dead lights are off... My client has requested I do install working dead lights on the sail, with its own on /off switch... Should be a nice effect?
· Premium Member
I've decided on going with the "First Season" version, complete with not only the port and starboard sail lights, but drilling out the portholes for the four sail hatches as well. :dude:
I like finally having the eight window Seaview. It will go nicely with the four window I already have.
Not being a Navy man I don't know much about subs so I have a few questions;
I can understand the need for front and rear cameras on the sail but why are the four "windows" on the sail called "dead lights"?
Why is there water tight doors just above the sail dive planes?
What are the four small rectangular bumps on either side of the sail for?
These questions are for detailing purposes.
· Premium Member
Depending on how AMS you and Mark want to be, you might want to consider eliminating the "diner booth" and replace it with flat walls as they did for season 1. (Of course it's at the deepest corner of the lounge and therefore not too visible ...)
· Premium Member
The new photos are great, Randy! You did a super job eliminating the central seam between the windows.
Quick question - what is going into the big hole you cut in rear hull under the missile silos? I assume it will be access to the electronics with the silo plate removable? (Of course you probably mentioned this is a post and I missed it by just looking at the pretty pictures.)
1 - 20 of 128 Posts
