Hi all,
I have a 1993 5 hp Briggs on a garden tiller. It stopped running while tilling the fall garden as if it were out of gas, yet the tank is half full (or half empty). I cleaned up the spark plug, but that didn't help. I'm tested that the plug still does produce spark so I'm guessing the plug is OK. I removed the plug, dropped a few drops of gas into the head, put the plug back in but still didn't get even a hint of it starting (only did this test once though). I'm not sure if the problem is with the carb or something else. Any hints on where to proceed next? The only thing out of the ordinary is that I had recently changed the oil and it was blowing smoke from the oil out the muffler. Maybe I put too much oil (or didn't get all the old oil out) and I've caused a problem within?
Thanks,
Joe
Thanks,
Joe
