Recently, a group of racers including myself had an enduro race with pancars.
We had 5 teams with 3 drivers per teams. Each team consisted of one 4300 BL car and 2 13.5 BL cars.
I was able to run my 13.5 car for over 8 minutes before I pitted to switch out with the next car. I was still pretty fast at the 8 minute mark but some of the other 13.5 guys had already pitted and I was starting to get passed by 13.5 cars with a fresh charge.
The goal was 600 laps. And the first car out had to be a 13.5 car.
It was the most fun I'd had in a while and it really put the 4200's to a unique test.
wonder why i'm only getting 450 sec and 3800 mah...i dis on a tray before race ,charge at 6, race, put 500s charge in pack, then on cycle day i dischg at 30,then charge at 6/dischg at 30...whats wrong here
Nic, I think the Turbo that you are charging on will only go to 3800mah. Start your charge and then stop it after 500 seconds and start charging again.
thats what i did but re-started after 1000sec....called CE and they said that would work. Even tried to repeak at 4 amps w a prophet charger and still got same results.
i didnt notice any lights go out early *shrug*. if i discharge to .9 v per cell, by discharging each cell individually with the turbo 30 is that the same as using a tray? i realize the tray dis rate is only 5 amps.
I don't want to get this thread into a discharger or equalizer debate BUT I've seem much better results with the last batch of 3800's and the new WC 4200's if you use a tray that the lights go out around .70 -.80 per cell and remove after just a couple minutes .
The days of the 0-30 for the new nimh's is over as the lights go out at .25 volt.
Whats your IR
Whats your voltage at 240 sec
How long are your races
Don't discharge after you race
Never discharge below 1 volt per cell at a high rate [ 30 + amps ]
