21 - 28 of 28 Posts
Steve,
When you clean out your motor, i take it you are leaving the brushes in? do u ever use a comm stick? do you spray out the motor while you are running it w/ the dremel tool?
you should not take your brushes out of the motor unless you are going to replace them and cut your comm.
you can also run the motor @ 2 volts and spray it out with "real" motor spray
alan behler
www.sureshotracing.com
rcavenger said:
Steve,
I leave the brushes in, spin the motor (counter clockwise) and spray out the motor while it's running.
I haven't use a comm stick in years.
Steve.
A lot of guys at our track and I take the brushes out and use a Q-tip to clean the brush face and comm, is this bad? What should the proper precedure be?
Justin #29
Justin #29
I leave the brushes in, spin the motor (counter clockwise) and spray out the motor while it's running. Works for me.
Steve.
i never take the bruishes out unless i rebuild.. al u have to do is take the wire from the screw to the capacitor off.. then the comm stick fits right in..
i break in my motors at 1 volt for 30 seconds... the lower amps seem to break them in faster. the motor is working harder to keep spinning, but not enough power to muck up the brushes... i hate every single comm drop out... in my opinion it does nothing fotr performance... people make all kinds of claims, but my best runs are on dry motors....
if i have a good set of brushes i will re serrate them until they are no good... and they seem to get better every run... if they were worse i would not reuse them...
hurricane golds love to be re serrated as do putnam greens... try serrating a brand new pair off 767's.. do it right over the serrations on them alreay.. then break in.. the motor should pull 12 amps at 2 volts... and have plenty of rip...
also my buddy has been running the built drops.. he gets 10-15 runs out of his 19 turns... no cleaning.. after his 11th run it was the best.. pulled a 109 on the fantom... the built drops are deisel fuel as far as i can tell. we used deisel fuel and had the exact same results...
Burbs.A tad off topic by what serrator do you use that(LASTS) cutting putman brushes.Bit goes dull as butter after a few pair.
i belive it is the promatch or the xxip bit. cant remeber... whichever one serrates better i got.. i havent noticed any problems with it dulling.. putnam greens are very soft... my serrator stil cuts like new ....as do all my buds.. i never heard of one going soft like u say...
21 - 28 of 28 Posts
