1 - 1 of 1 Posts
*Click the images to buy
Number of 3Racing RC Hop Ups Parts and Accessories back in stock @ rcMart.com. Including parts for Tamiya, Axial, Traxxas and more. Please check the following list for the recently restcoked items:
Item No. Description
3RAC-AD12/BU 12mm Brake Adaptor - Blue
3RAC-AD12/LB 12mm Brake Adaptor - Light Blue
3RAC-AD12/OR 12mm Brake Adaptor - Orange
3RAC-AD12/RE 12mm Brake Adaptor - Red
3RAC-BB01/RE Sub-C Battery Straps Socket - Red
3RAC-NLD03/BU 3mm Normal LED Light - Blue
3RAC-NLD03/OR 3mm Normal LED Light - Orange
3RAC-NLD03/RE 3mm Normal LED Light - Red
3RAC-TR315 64 Titanium 3mm Turnbuckle - 15mm (2 Pcs)
3RAC-TR318 64 Titanium 3mm Turnbuckle - 18mm (2 Pcs)
3RAC-TR321 64 Titanium 3mm Turnbuckle - 21mm (2 Pcs)
3RAC-TR325 64 Titanium 3mm Turnbuckle - 25mm (2 Pcs)
3RAC-TR328 64 Titanium 3mm Turnbuckle - 28mm (2 Pcs)
3RAC-TR332 64 Titanium 3mm Turnbuckle - 32mm (2 Pcs)
3RAC-TR335 64 Titanium 3mm Turnbuckle - 35mm (2 Pcs)
3RAC-TR338 64 Titanium 3mm Turnbuckle - 38mm (2 Pcs)
3RAC-TR342 64 Titanium 3mm Turnbuckle - 42mm (2 Pcs)
3RAC-TR345 64 Titanium 3mm Turnbuckle - 45mm (2 Pcs)
3RAC-TR348 64 Titanium 3mm Turnbuckle - 48mm (2 Pcs)
3RAC-TR355 64 Titanium 3mm Turnbuckle - 55mm (2 Pcs)
3RAC-TR362 64 Titanium 3mm Turnbuckle - 62mm (2 Pcs)
3RAC-TR365 64 Titanium 3mm Turnbuckle - 65mm (2 Pcs)
3RAC-WX124 Wheel Adaptor (4mm) - Thick
416-08/LB Servo Post For 416
416-13 Front Belt For 416
416-14 Rear Belt For 416
AWD-15 Aluminum Diff. Outer Join For Mini-Z AWD
AX10-15/GR Drive Shaft Set For AX10 Scorpion
AX10-32/GR High Clearance Knuckle For AX10 Scorpion
BDY-F109RK Replacement Kit for #BDY-F109 F1-09 Lexan Body Polycarbonate Body
DB01-06/LB Aluminium Rear Suspension Mount For DB-01
F104-03/LB Servo Tray For F104
F109-03/FRP Main Chassis and Upper Deck FRP For F109
F109-07/FRP Motor Plate FRP For F109
F109-08/LB Aluminum Motor Mount For F109
GT-08/LB Aluminum Bearing Sterring Saver For GT-01
M03M-01RG Rebuild Kit (Gear) For #M03M-01/LB
M05-02 Fast Gear Set For M05
M05-03/WO Graphite Front Shock Tower For M05
M05-04 Front Bumper Set For M05
M05-06/WO Graphite Rear Shock Tower (M&S) For M05
M05-08/WO Graphite Bulkhead Stiffener For M05
M05-14/LB Motor Heatsink Outside For M05
M05-20/WO Graphite Battery Holder For M05
M05-22/LB Steering Servo Linkage 95mm For M05
M05-23/LB Front Body Post Mount For M05
M05-24/LB Body Post Binder For M05
M05-27/LB Front Solid Axle For M05
M05-29/WO Graphite Gear Shaft For M05
MC-01 Front Brake Disc For Motor Cycle
MI-04/LB Aluminum Front Knuckle Arm For Micro-T
MKF-03/BU Aluminium Ball Diff. Shaft For MIni Z F-1
MKF-05/WO Rolling Damper For MIni Z F-1
MRC-02/BU Drive Shaft Set For Mini-Rock Crawler
TA05-IF16/LB Aluminium C Hub For TA05-IFS
TB03-08 7075 Solid Axle For TB-03
TM-001/BU Aluminium Oil Damper For Traxxas E-Maxx, T-Maxx & S-Maxx - Blue
TM-001/GO Aluminium Oil Damper For Traxxas E-Maxx, T-Maxx & S-Maxx - Gold
TM-001/PU Aluminium Oil Damper For Traxxas E-Maxx, T-Maxx & S-Maxx - Purple
TM-001/RE Aluminium Oil Damper For Traxxas E-Maxx, T-Maxx & S-Maxx - Red
TR-180003/V3 3Racing Carrying Bag Ver. 3. For all transmitter ( Gun / Stick )
TT01-02 Outer Join For TT-01
TT01-08/LB Aluminum Motor Mount For TT-01
V3R-032/V2 Aluminum One Piece Engine Mount Ver. 2 For V One RRR
WH-15/WI 5 Spoke Tyre and Rim Set For DF-03 - White
WH-16/SI 5 Spoke Tyre Set For RC18R - Silver
WH-18/SI 5 Spoke Tyre and Rim Set For Lazer ZX-05 - Silver
WH-28/GR 2.2 Inch Crawler Tyre Set - Mesh ( 4pcs) - Green
WH-31/BU 2.2 Inch Narrow Crawler Rim Set - Mesh (4pcs) - Blue
WH-31/GR 2.2 Inch Narrow Crawler Rim Set - Mesh (4pcs) - Green
WH-31/LB 2.2 Inch Narrow Crawler Rim Set - Mesh (4pcs) - Light Blue
WH-31/OR 2.2 Inch Narrow Crawler Rim Set - Mesh (4pcs) - Orange
WH-31/PU 2.2 Inch Narrow Crawler Rim Set - Mesh (4pcs) - Purple
WH-31/RE 2.2 Inch Narrow Crawler Rim Set - Mesh (4pcs) - Red
XN1-24/RE Aluminum One Piece Engine Mount For NT1
1 - 1 of 1 Posts
