What changes have you been making now that we are running single cell vs your old two cell setups? Softer on the front? Stiffer on the rear? Preload, rake? Left side weights. What did you change and why? Need some help here guys. I'm not a wheel man, but I do better with a car that's decent. Thanks in advance.
For flat tracks:
Cars are lighter.
Less tire wear.
I'm using the same weight percentages in my setups.
Just takes moving weight around differently.
Leftside weights has changed.
Same springs just less tension in the front.
Gearing less as well as motor timing.
Thanks, looking to try your software out soon!
Yes flat track med bite until the mains then the bite comes up quick.
