Are you referring to this body style?anyone know if i can get a chevy s10 extended cab body? i want a replica of my 95 s10 in ho scale....
Did you have the intake manifold gasket problem that plagued those engines?Ugh I had a '94 S-10 and it was the biggest POS I ever owned. Still, style-wise I'd pick the S-10 over a Ranger or Dakota from the same timeframe.
Good luck with your quest!
Mine does not have the weird shaped wheel wells. I was able to get a 4x4 with symmetrical body colored wheels wells (i.e. not the z71). Not sure if they still make them that way.The asymmetrical rear wheel well bulges on the Colorado make me twitch. It's such a bold design choice that you either love it or hate it and I fall into the latter category. I've owned Chevy's and always had great luck with them from a running gear perspective. Bodies and everything semi-attached to the body, not so much. I also owned a Dodge RAM for 10 years and it looked great but 12 mpg city and 12.001 mpg highway made commuting a huge expense.
Yep -- that and a lot more, from the ignition system, to the brakes, etc., etc. Was a big waste of cash. The first year I had it it worked fine, no issues. Then it seemed like as soon as I spent a wad of cash to fix a problem, a week or two later a new problem surfaced. Maybe I had a lemon, whatever, all I know is the only things that worked without issue were the trick entended visors and the Toyo tires I added. :freak:Did you have the intake manifold gasket problem that plagued those engines?
heh heh... guess we were lucky we got rid of our '94 S-10 Blazer after less than two years. we actually really liked it, but the payments were pretty high, and then my wife got pregnant with our first... out with the new Blazer, in with the used Taurus wagon. now THAT was a bucket of carp... only took me two sets of head gaskets to figure that out. the 3.8 made it pretty quick, but apparently that engine has ALWAYS had issues.Yep -- that and a lot more, from the ignition system, to the brakes, etc., etc. Was a big waste of cash. The first year I had it it worked fine, no issues. Then it seemed like as soon as I spent a wad of cash to fix a problem, a week or two later a new problem surfaced. Maybe I had a lemon, whatever, all I know is the only things that worked without issue were the trick entended visors and the Toyo tires I added. :freak:
And that AMC SX/4 (thats what the 4wd version of the spirit was called) is pretty sweet! 32's on an S-10, huh? Hope it had an engine swap. Those 2.8 V-6 engines are notorious for being gutless! My Jeep rolls on 32s now and with the 4.0L its still way underpowered. Needs a Hemi!
