I think the clunky looking boxy wing on the green one is like that cuz that's the earlier cast... the yellow and blue ones in the picture are the later re-vamped casting...Galaxieman said:Why is the horizontal piece on the wing square looking?It looks like a homemade box sitting between the uprights as compared to the others and the ones I have :hat:
The wing is like that on the real 1:1 1969 Charger Daytonas, as can be seen in the picture below:Pablodragon said:I think the clunky looking boxy wing on the green one is like that cuz that's the earlier cast... the yellow and blue ones in the picture are the later re-vamped casting...
The wing actually helped keep the car on the ground at high speeds above 190+ MPH and provided downforce. The large size of the wing on the Daytonas was so that the trunk could open up on the production version.sschevyman1 said:That wing is clunky to slow it down!!!!
Revamped castings?.Those are totally different cars and the real ones didn't share any of the same sheet metal.The fiberglass spoilers and front clips weren't exactly the same either.Pablodragon said:I think the clunky looking boxy wing on the green one is like that cuz that's the earlier cast... the yellow and blue ones in the picture are the later re-vamped casting...
You are right as well, and it must have been so cool to see them going past your house every day. Many say that the production of the Daytona is 505, but the actual amount was much lower. Creative Design counted some of the same cars twice when they were being sent out, since NASCAR required a certain amount to be built to qualify for homologation.McRooster said:Revamped castings?.Those are totally different cars and the real ones didn't share any of the same sheet metal.The fiberglass spoilers and front clips weren't exactly the same either.
Although dodge and plymouth made things that looked alike,for example the Challenger and Cuda had no interchangable parts,and niether did the daytona or superbird.
I grew up eight blocks from Dodge main in Hamtramck and a mile from Lynch Road Asssembley.My Grandfather and Father both worked and retired from those plants.
I lived on the I-94 service drive from 1967-1977 and EVERY car carrier that left those plants had to drive right in front of my house to get on the freeway.2 trucks loaded with mopars,back to back every 15 minutes,24 hours a day six, sometimes 7 days a week.
Those cars ruled the streets of Detroit.It was fun in the summer,sitting out on the front porch in the middle of the night when it was really quiet.Many times you'd hear a loud growl in the distance,something that sounded like a fire breathing dragon.
It would get louder and louder as it grew closer and you could feel the porch
start to vibrate and the windows in the house shook.
Then it would appear.It was always one of the mighty mopars from either one of those plants,usually being driven and pushed to the limit by an engineer or test driver for Chrysler.
The Hamtramck plant had Barracudas,cudas,challengers,darts,demons,dusters,and valiants.
The Lynch road plant had belvederes,chargers,coronets,and satellites.
Production numbers were:
1969 Daytona = 505
1970 Superbird = 1,920
1970 AAR cuda = 2,496
1970 Challenger T/A =2,104
Just wanted to share a little mopar info.I'm into them so much I can read build sheets and have access to original options,prices and production numbers.
I don't know if they would be ABS(I work in plastics) odds are they would be polycarbonate(LEXAN).That stuff is hard as hell and very light.sschevyman1 said:Those noses on those cars were metal,but today they would be ABS Plastic.
