Engine model number is 31Q777. I changed the oil and after a few times mowing the yard it started to leak oil out of fuel pump. Replaced fuel pump, still does it. It also has oil comming from dipstick tube. While engine is running and you remove dipstick it sprays oil every where. We tore it down and adjusted valves, check breather tube, and breather reed. All look good. Any sugestions. This thing has only 191 hrs on it. About 20 hrs of that is leaving key on, LOL. Any help would be appreciated.
Never remove the dipstick from a running engine! Make sure the engine is not overfull of oil. You may want to remove the oil breather and make sure the drain is not plugged. I would be suspicious of a blown head gasket as the cause of your problem.
Well, then I would look for a leak into the crankcase that is preventing a vacuum from forming when the engine is running. A leaking sump gasket, top or bottom oil seal, dip stick seals etc...
Best of Luck.
