hello i have a kohler command 12.5hp engine. its horizontal right now but i want to put it in a riding mower with vertical shaft. this engine can be bolted down vertically because you just switch the oil dipstick to the other hole provided and th carb needs switched around. there is motor mounts for vertical so it must work that way to.
is this possible?
is this possible?
