Hi , i have an old tucemseh craftsman tractor that is probably 10 years old and i bought it for 20 dollars. I had to replace the deck belt and the the transmission belt. Then i had to put a new carb on it. i had it running for a while and still do but if i let it sit for a while the next time i start it up it will smoke thick white smoke out of the muffler. I had let it sit for about a month and when i returned to it it had some oil leaked on the ground from the muffler. I was wonder if this is a cracked engine block or the gasket on the head is bad. The OHV's gasket is fine though. What could be causing this?
Thanks Matt
Those older ohv Tecumseh weren't bad motors, my neighbor had one last 25+ years before he sold the tractor. Check your oil for gasoline contamination, this would indicate a carburetor issue like what pyro stated. Those engines engines if parked on an incline were known for blowing smokes when first started, but were not known for blowing head gaskets.
Thanks, I checked out my OHV gasket and it is letting some oil drip down on to the muffler, then letting it smoke. But i still see that it blows some smoke out of the muffler. I took it all apart but i didn't know how to remove the OHV box, so i couldn't remove the cylinder head to check the piston ring gasket. If i do fix the gasket on the OHV box and it still blows some smoke out the muffler should i clean out the fuel tank? What are some ways to clean out a fuel tank?
