1 - 2 of 2 Posts
Hey, I was wondering how to remove gas out of the oil pan in a 12.5 hp tucemseh. Would you just flush it out with more oil by doing a couple of oil changes or is there any other way i can do that? My tucemseh is still smoking out of the muffler and im wondering why oil is dripping out of a side little compartment that comes from the OHV. It is on the same side where the carb is and it has a little stringy filter?
drain your oil completely, you have a carb problem which may be a defective float or worn needle seat , gas is not stopping when carb bowl is full and its getting to your crankase and coming out of the breather . make sure you fix your carb first and add oil to your crankcase last.
1 - 2 of 2 Posts
