it starts and runs if I put it at high idle it starts to run rough like it is out of gas then dies it will start again and run for a awhile and do the same thing
Any ideas??
Thanks
Adjust Carb?
Any suggestions on the adjustments it has a high idle screw and an Idle screwand another srew that is flush with carb
any help there
1.5 turns out from all the way in snug as a baseline.... fine tune when its warmed up some (air filter on for high, does make a little difference) and it should rev up and back down with little to no hesitation.
Adjust Carb?
it acceratates fine now, but when I am in high idle decrease it to slow idle I get some sputter & backfire going from high to low
You may if you throw the throttle down fast, get a few sputters....
But backfiring sounds like it needs a carb rebuild (carb kit, tear it apart, soak it in carb cleaner and blow all holes out with compressed air)
