41 - 60 of 80 Posts
Discussion Starter · #43 ·
Spent a couple hours adding filler to the raised sections of the hull and cutting out the windows for this section. I also plan to add details to the forward ends of the raised sections to mimic the details seen on the Constitution class ships. Who can spot the Space:1999 Eagle parts on this section? There are two big parts, one heavily modified, they are obvious when you see them.
316666
Starship Class
Ha! (y) Brilliant use of that part--cut in half, I'm assuming. I was admiring you for having put those grooves in but now that you've pointed out where the part came from . . .
I've found some cheap measuring scoops have similar shapes to what you have on the front.
Discussion Starter · #46 · (Edited)
The bells come in 2 parts, no cutting needed! The cone shaped section on the rear is a complete bell with .020 sheet added to build up the larger section to eliminate the step that exists between the two halves, I also cut off the mount on the small end of the bell and added a dome to finish it out.
Cutting the grooves is not that difficult to do when I need to do it, I draw the line in pencil then use a razor saw to slightly cut along the line followed by careful work with a small triangular file.
316667
Discussion Starter · #47 ·
Made a better looking deflector dish:
316823
Last details added to the deflector/sensor pod:
316824
I also started adding filler to the main body of the ship, I want to add some windows to the aft of the engineering decks as well as a few to the hangar/cargo section. This ship will not have the standard Starfleet markings since it is a UESPA ship that utilizes Starfleet technology.
Starship Class
Looking more TOSy all the time. (y) That deflector pod looks really good.
Starship Class
Fantastic work! (y) I especially like the detailing around the shuttlebay entrance and the rear-facing sensor dish.
  • Like
Reactions: krlee
Discussion Starter · #53 ·
I kept looking at the flat areas at each side of the shuttlebay, wondering what could go there and then I remembered on Enterprise they had work pods. This is the perfect place for them, no need to depressurize the entire shuttle bay just to launch a pod. The plain dome on the end of the deflector/sensor pod did not look right to me so I stuck on a small sensor dish, I tried a larger one at first but it did not look good so I cut it down until it looked right.
Discussion Starter · #58 ·
I added the clear windows to the pilot parts bridge module and after touching them with paint i decided that I did not like the fit of the windows. I removed the clear parts and started adding custom made inserts made from .080 x .188 strip styrene.
320289
I filed the end of the strip to about 45 degrees.
320290
I then cut the insert to length and glued in place.
320291
A much better fit and look than the kit parts.
320292
Windows done on this part. I had already added the clear parts to the lower saucer windows, those will need to come out as well.
320293
Discussion Starter · #59 ·
Had to use a grinder bit but I was able to remove the lower hull clear kit windows and I now have all the windows in place. I still have to cast the clear parts for the running lights which I will tint the proper colors. Next up I will detail the shuttle bay interior since I have decided to leave the doors in an open position.
320308
Discussion Starter · #60 ·
First paint on the secondary hull, I am using Tamiya AS-5 Light Blue as the main color. I masked off the leading edge of the dorsal pylon to leave it the natural blue color.The recesses windows will be painted in by hand with white and a few blacked out windows.
320310
41 - 60 of 80 Posts
