21 - 40 of 65 Posts
BANNED
ah .... the memories.
beam me up, there is no longer intelligent life here!
Starship Class
Wow! Nice. :thumbsup:
BTW: Just curious: do you use the corrected aftermarket impulse engines on your refit models?
Starship Class
No. I used the kit part. I did however, use an aftermarket "Bridge" That is much closer to the filming model. In all honesty, the Impulse engines I could live with...That bridge however...
Gotcha! You know, I really thought the impulse engines (which the model company admitted just plain giving up on trying to get the Chinese to get correct) would be the big thing that everyone wanted to get an aftermarket part for due to its shape being quite a bit off. As things turned out, hardly anyone cares or even notices. :surprise:
Special effects model refit Enterprise impulse engines off
Special effects model refit Enterprise impulse engines firing
R2 refit Enterprise impulse engines
Discussion Starter #36
You have to pick and choose your battles...There are a number of slightly off and incorrect things going on around here. But it's just a model and the builder can decide how far to go with it.I actually may correct the area at a later date. Currently,however, I simply don't have the time.
Starship Class
Agree on all points :thumbsup:
Mark,
The build looks real good! You stated you used the Orbital Drydocks masking set. Have you ever used the TrekModeler masking set? It looks very detailed, but very expensive as well. Keep up the outstanding work.
Thanks
Phillip1
Discussion Starter #39
Mark,
Thanks
Phillip1
Many thanks my friend! No I haven't used the TREKMODELER masking set...Perhaps in the future, I still have three more of these to do!!!:crying:
21 - 40 of 65 Posts
