Brad,
I try to put numbers in perspective this way.
1.24v vs. 1.23v is 1.008% so the 1.24v would be .8% better.
That would be like taking a 18,000 RPM motor and being able to spin it at 18,144 rpm's
That would be like taking a WATT or Power # of 70 watts to 70.56
and probably the most important number
That would be like taking a lap time from 4.000 dropping it to 3.968
so if EVERYTHING else is PERFECT, you would have gone from a PERFECT 60 lapper in 4 minutes to just quick enough to get that EXTRA lap and finish with a 61.
Most racers don't make small enough "fine tuning" adjustments in my opinion to see that difference.
Ask yourself - Do you calculate gear ratios and adjust them .05% or less, or do you run the POPULAR roll out?
Do you change a set of tires to achieve a .05% gear increase or decrease? (2.15" vs 2.167" or 2.15 vs. 2.145) MOST don't, and most wouldn't really see the difference.
<-- flame suit on
