Haven't posted here in a while...an update. I finally have a pearl finish on the engineering hull I am comfortable with.
The key was subtlety. To the eye she is almost white, but in the proper light the pearls pop...
First the pattern (Tetris anyone?)...
http://galaxyphoto.com/ent/pattern_final.jpg
This shows the subtlety (HOWEVER, it has even less contrast to the eye)..
http://galaxyphoto.com/ent/starboard_final.jpg
Above the bay..
http://galaxyphoto.com/ent/bay_top_final.jpg
I think this would look pretty good with a more direct light...
http://galaxyphoto.com/ent/approach_final.jpg
A B&W compare. Not an exact pattern match but certainly the "feel" (BE SURE to scroll down)...
http://galaxyphoto.com/ent/B&W_compare_final.jpg
Finally, Since I am building "A", she needs to be dirtied up a bit. I will be adding a very subtle overlay of non-pearl "L" panels, the little L shaped panel weathering that ILM did. I used the high res auction shots to lay out the approximate location of the L's and made a mask in Photoshop. The original is a bit dirtier, not sure if that is by design or from years of abuse.
Be sure to scroll down for the comparison...
http://galaxyphoto.com/ent/fan_tail_compare.jpg
Above the bay..
