1 - 20 of 28 Posts
This is a project that’s been brewing in the back of my head for some time—a model of the original iteration of the 8-foot Enterprise model as originally constructed for STAR TREK- THE MOTION PICTURE.
For those who don’t know, the original Enterprise was redesigned by her creator, Matt Jefferies, for the aborted PHASE II TV series. I built that version a few years back.
306677
PHASE II morphed into TMP, with Richard Taylor and Andy Probert, among others, reworking the design for the big screen, retaining Jefferies’ basic concept, but radically altering the surface detailing and markings. The model was constructed, but damage to the Bridge after a water leak, as well as Doug Trumbull coming aboard and suggesting the self-illumination spotlight effect for the ship’s registry markings, led to the model being modified into the onscreen version we know. The Bridge, B/C deck, and lower saucer sensor dome were all modified and/or replaced, and various markings were removed/added/modified.
David Shaw’s comparison of the Jefferies PHASE II design and the Taylor’s redesign:
306676
Early version of Taylor’s blueprints, with the name and registry incorrectly positioned on the lower saucer (this was corrected for later iterations, which flipped the registry and moved the name to just in front of the dorsal).
306678
I’ve been collecting images of the blueprints, concept art, the model under construction, test shots of the model (sans markings) which made their way into licensed products, the “finished” model, and licensed toys and art based on the original model. The original decal art is also on the Internet (including the original secondary hull pennants, etc.) I think I have enough to proceed. I ordered replacement parts for the Bridge, B/C decks, and lower sensor from Shapeways. The other physical changes will be easy to make. And I ordered some 1/1000 supplemental decals which come with lots of red pinstriping, since this early iteration of the ship had tons of it.
Mike Minor production painting.
306679
The model under construction:
306680
The original decal sheet. Note the TWO large “NCC- 1701”s (the lower saucer’s was originally the same size as the upper’s), and the original secondary hull pennants.
306681
Example of one of the test shots of the model, with no markings, and the torpedo tubes open and illuminated:
306682
The only image I know of which shows the “finished” model, before the modifications which turned it into the onscreen version:
306683
Some details vary between different sets of drawings and different photos. Here’s my list of differences between the Taylorprise and the final TMP version. Some details are still in question.
SAUCER:
*Pinstriping around perimeter, linking the red pinstripes around the RCS thrusters (the thruster pinstripes remain on the model to this day).
*Pinstriping around impulse engine housing and the individual engine housings.
*Pinstriping around landing leg hatches (which are NOT painted “engineering green”, but rather have horizontal Aztec pearlescent stripe pattern.
*Concentric pinstripes linking phaser banks.
*Big “NCC-1701” on upper saucer located one grid-ring closer to bow than on final model. Another big “NCC-1701” (bigger than final version) on saucer underside, which is also closer to the bow.
(?)*Forward (blue “T” shape) section of impulse crystal housing (the bit that sits between the impulse crystal and the rear of the B/C decks) originally drawn and built with squared-off front edge. May have been changed to the rounded version seen on the final model during construction.
* No gangway hatch/mounting point on portside. No “Starship U.S.S. Enterprise” or “United Federation of Planets” text, as seen on either side of the hatch on final version.
* Totally different Bridge and B/C deck.
*Simple sensor dome on underside, with no spotlight housings.
DORSAL:
(?)* “Starship U.S.S. Enterprise * United Federation of Planets” text (which would later be relocated to within the secondary hull pennants on the final model) located above saucer/dorsal hull separation line, as seen in Probert’s saucer-separation sequence storyboards.
(?)* Is there “engineering green” on the dorsal and secondary hull for this early iteration? Hard to tell. Perhaps an earlier, less-detailed version? Or were the green areas all hull-white? At the very least, the inboard nacelle pylons did not have the green stripes.
* Different torpedo tubes. Horizontal divider in the center separating two torpedo tube hatches which slide open vertically. When closed, there is a horizontal seam line across each hatch.
*Pinstriping around torpedo housing.
SECONDARY HULL:
* No radial “spokes” on deflector dish.
* The three “space- energy-field attraction sensors” surrounding the deflector dish are less detailed, and are missing the tapered platforms which sit in front of them and face forward.
(?)*No “engineering green” on strongback and deflector housing?
(?)*No deflector gridlines, except for the removable mounting panels on the sides and bottom?
*The Starfleet arrowheads are the same, but the pennants are not. No “Starship U.S.S. Enterprise * United Federation of Planets” text. Just four red stripes, similar to the TOS look.
*Different Aztec pattern on belly of secondary hull, resembling arrows pointing forward.
*Paul Olsen’s random “streaking” Aztec effect on rear cutout/fantail.
*No spotlight housing on fantail undercut, just a running light.
*Pinstriping running around deflector housing and upper spine, between nacelle pylons.
NACELLE PYLONS:
*No “engineering green” stripes on inboard sides.
* No blue accent color on leading edges.
NACELLES:
*No spotlights on front ends. No blue accent color on front ends.
*Pinstriping around “magnatomic flux constrictor” (the round, grooved copper bits) housings and also running around the main nacelle grilles, both inboard/outboard.
*Different Aztecing toward rear of nacelles, with horizontal block pattern instead of diagonal stripes
*No “United Federation of Planets” text beneath “NCC-1701” markings.
(?)*Vertical panel lines at rear of nacelles, although these may only be on the blueprints, and perhaps never made it to the model.
Any additional data or corrections would be appreciated. I’m still in the research phase of this project. I’ve collected enough images to come to the conclusions noted above, but more reference is always useful. Thanks!
This is a version of the refit I’ve always wanted to see modelled since buying Starlog #25 off the stands. Can’t wait to see how you progress!
A very cool project. I must admit, I had noted the refit decal sheet Paul Olsen was "selling" (if you donated a certain amount to his "ProjectEnterpise" boondoggle:rolleyes:), but somehow failed to notice the earlier secondary hull pennants or larger undersaucer registry font.
I have always been partial to the South Bend Electronic Enterprise, a toy I lusted after in my childhood but never got (and have resisted the urge to acquire in my middle age). Lots of similarities to the version you are building.
That’s because of the lead time in producing merchandise and promotional materials. The South Bend toy (among other items) was based on reference images of the early version of the model.
What baffles me is how the recent Eaglemoss XL 1701-A model is ALSO based on the Taylor version, at least in terms of the Bridge and B/C deck (although it’s still painted like the final version).
Makes perfect sense. Like the Milton Bradley jigsaw puzzle of the TMP Enterprise, or certain images of the ship depicted on the 1979 Topps bubble gum card set. As a kid, the differences caused about as much confusion in my mind as the re-use of shots of the pilot versions of the ship throughout TOS. Just a little bit of "history repeating".
Another thing I somehow never noticed from the aztek-painted shot of the Taylor version (until you pointed it out) was the lack of the inboard green stripes on the pylons.
My own favorite version of the refit enterprise was the "penultimate" one with the purple flux chillers, blue impulse exhaust vents, and seemingly always lit photon launchers. It appeared that way on so much marketing material (even the Kimble cutaway poster) that for years I thought the chillers in the film were purple (despite seeing it a million times). On that note, I noticed for maybe the first time just recently that the impulse vents in ST:V were once again blue in at least a couple FX shots.
Discussion Starter #7
That has more to do with lighting and color filters and whatnot.
For the publicity photos, they clearly lit up the photon tubes along with the warp and impulse engines (...which technically shouldn’t be running at the same time!) to show off the lighting effects.
The nacelle grilles were most definitely purple, and I suspect that the impulse engines really were blue (as noted, in STAR TREK V, a film with low-quality, unpolished effects, they’re also blue), but both of those lighting effects were tweaked during VFX filming and/or color-timing to make them look blue and red, respectively.
You mean the chillers were purple on the model at one time, yes? As far as I know, the chillers in ST:V were blue, as in all other movies.
I never considered that the impulse exhaust vents and / or nacelle chillers could have been color coded "in post". I had wondered if maybe the shot(s) I was thinking of in ST:V with blue impulse vents were cases where old publicity shots were used; I had heard that in some cases, the effects even of the ship moving in that movie used stills.
Discussion Starter #9
On the model, the chillers were purple, and have remained so for decades. Onscreen, filters and color grading and whatnot shifted them to blue.
As for STV, the new FX team clearly didn’t have experience with the model, and so the impulse engines glowed blue because they didn’t use the same filming techniques that Trumbull and ILM did in the previous movies. All of the STV shots were new, and featured the model with its 1701-A livery.
The TMP publicity stills of the post-Trumbull-changes model are the final version of the model, but without the tweaked lighting effects as seen onscreen. Hence, blue impulse and purple nacelles.
Discussion Starter #11
The beginning. Installed the new Bridge and lower sensor dome, as well as removing the structures surrounding the deflector dish and building the new torpedo tube housings.
306738
The B/C deck part I received from Shapeways is a bit too small in diameter to match the blueprints and the reference photos, so I’m enlarging and reshaping it with Apoxie Sculpt.
Discussion Starter #12
Studying the reference. Despite it not appearing in the blueprints, I’m pretty sure they added on the secondary hull deflector grid when building the model to disguise the three mounting hole covers, and that it wasn’t added on during the Trumbull revisions.
Also, I’m pretty sure there’s a Starfleet arrowhead on the rear of the B/C deck structure, just above the four VIP lounge windows. Some blueprints show a tiny one to the starboard side of the Bridge airlock (and a tiny one above the shuttlecraft hangar doors, but it looks like they rethought that when building the model).
Still not sure whether there was “engineering green” for the strongback/dorsal/deflector mount on the Taylor model as built. Maybe just normal Aztecing? Some other base color which was later repainted with the elaborate green patterns? Plain white?
Discussion Starter #14
After some more study of the reference materials, I’m thinking that there WAS some kind of simple, colored panel pattern on the strongback and the dorsal (but NOT the deflector housing, which also lacked RCS thrusters). There appears to be a vertical strip on the dorsal, but one that is wider than the final version. My guess is that, when the model was refined and more detailing was added, THAT’S when Ron Gress came aboard and designed the more ornate, “engineering green” patterns, and also added the stripes to the inboard nacelle pylons, and the green to the deflector mount.
Probert’s saucer separation storyboards color the strongback and dorsal strip yellow (not a literal interpretation of the model, obviously), but leave the deflector housing hull-white. Although there are also a few details in those storyboards which edge the design closer to the final version, such as the “T”-shaped detailed added to the three round bits on the deflector housing.
306769
I’m thinking of going with a pale gray-green color and designing a simple panel pattern for the strongback and dorsal.
Found a better resolution photo of the Aztek painted Taylorprise above here that is somewhat revealing (at least to me; seems to suggest a "brickwork" strongback, and a black dot (if one tries to lighten?) behind the observation lounge on the B/C deck? Not top mention the clearer-than-before pinstriping on the upper spine that ascends the trailing dorsal somewhat, around the concentric phaser "ring" and saucer edge)::
306821
Some more clues to the pinstriping placement (esp. on the nacelles) on the Rick Sternbach painting below, from the final page of the wonderful "Star Trek Spaceflight Chronology":
Pretty sure that first shot is of the Phase II model not the TMP model.("Taylor" configuration or otherwise). [ON EDIT: I took too long to compose this post, so Gregatron beat me to the punch]
I had been doing a lot of Googling on this topic of late, found some interesting photos showing the Taylorprise that I was prev. unaware of, such as the ones below.
I have to add, this thread has cost me a bit of money (Thanks, Gregatron;)), as it has encouraged me to buy one of the South Bend Electronic Enterprises I prev. managed not to acquire (over reluctance to buy a toy).
307164
Discussion Starter #20
Hadn’t seen that one before. Another test shot with no markings and the torpedo tubes open and lit.
1 - 20 of 28 Posts
