As a companion piece to my recently completed TOS bridge turbolift alcove, I have started work on a 1:10 scale bridge station. Like the alcove, the bridge station is being scaled to Art Asylum/Diamond's excellent TOS action figures.
The pieces below were taped together for a test fitting.
Spock is standing on a small platform because the legs of the station have small tabs on them which I will use to aid in positioning and gluing it to its base, so I put him on the platform so his height would be correct in relation to the station behind him. (Even though this will not be Spock's station, I like to use the Spock figure because Leonard Nimoy was right around 6 foot tall which makes for a convenient "yardstick" when checking my build against photographs from the series.)
I am using the McMaster bridge blueprints as the basis for the build.
For additional support I will be adding a third "leg" in the middle of the station pretty much identical to those on each end.
I am building this with an eye towards lighting it.
Comments and suggestions welcome.
