Modeling power tools - HobbyTalk
Reply
post #1 of 17 (permalink) Old 06-29-2011, 09:34 PM Thread Starter
HobbyTalk Pro
I recently purchased a Micro Lux sander from Micro Mark. It has been a wonderful addition to my modeling tool arsenal. It got me to thinking, what power tools do you guys have on your workbench? Which are the most useful?
The only powered modeling tools I have are the aforementioned sander and a Dremel.
Fozzie is offline
Sponsored Links
Advertisement
post #2 of 17 (permalink) Old 06-30-2011, 12:06 AM
HobbyTalk Pro
Just a no-name motor tool/minidrill/sander.
Everything else get done manually with files, sand paper and modelling knives.
Xenodyssey is offline
post #3 of 17 (permalink) Old 06-30-2011, 12:09 AM
Member
Rocket45's Avatar
I model cars, and I just have a dremel. Same as Xenodyssey everything else is done manually with sand paper. Occasionally Ill use my power sander, but not very offten.
Thought I would put my two sense in!
Thanks!
Rocket45 is offline
post #4 of 17 (permalink) Old 06-30-2011, 12:46 AM
Member
A belt or disk sander is really useful for resin or vacuum formed kits where you want to remove a lot of excess material - probably not so much for injection moulded kits.
I also like the black and decker "power file" which is basically a 1/2" wide belt sander attached to a handle which I last used to thin out the trailing edge of the wings of a vacformed 747 with a 3ft wingspan. I then went over it with a file and 80 grit sandpaper.
Those little dremel drum sanders and cut-off disks are useful too.
For fine work I prefer needle files followed by sandpaper.
b26354 is offline
post #5 of 17 (permalink) Old 06-30-2011, 02:27 PM
HobbyTalk Pro
Trekkriffic's Avatar
Ditto what they said. Just a dremel. Most of my sanding is by hand unless I'm grinding on brass or other metal. I don't usually build anything other than styrene models. I am tempted to try converting an electric toothbrush to a sander someday as I've heard can be done.
Trekkriffic is offline
post #6 of 17 (permalink) Old 06-30-2011, 02:57 PM
Elder Statesman
Jafo's Avatar
Robarts paint shaker.....
Jafo is offline
post #7 of 17 (permalink) Old 06-30-2011, 02:59 PM
HobbyTalk Pro
Quote:
Oh yeah I forgot! I have one of those too!
post #8 of 17 (permalink) Old 06-30-2011, 02:59 PM
Member
Rocket45's Avatar
Something else I use to paint is an Rustoleum spray gun attatchment. You can find them in Wal-mart for $2.50. It sure does ease up on the finger.
Thanks!
Rocket45 is offline
post #9 of 17 (permalink) Old 07-02-2011, 11:42 AM
Elder Statesman
starduster's Avatar
I have a Unimat Sl 1000 with most all of the accessories, a table saw and a jig saw attachment which I use a lot of the time. I've done a lot of milling and this is the most used piece of modeling equipment I have. along with a belt and disc sander and electric drills I have a complete shop for modeling. Karl
starduster is offline
post #10 of 17 (permalink) Old 07-02-2011, 12:56 PM Thread Starter
HobbyTalk Pro
Micro Mark has a "power nibbler" that I'm looking at (my wife wants to know what to get me for my b'day). Anyone have any experience with one of these?
http://www.micromark.com/Power-Nibbler,7779.html
I'll take comments and opinions even if you've never used one.
Fozzie is offline
post #11 of 17 (permalink) Old 07-03-2011, 03:01 PM
Elder Statesman
starduster's Avatar
Fozzie, I have a nibbler but it's hand powered like using pliers, I've made windows for ' O ' scale trolley cars and with the hand operated nibbler I have control on how much material I can remove, with this powered model close tolerances are a question. but for cutting larger pieces I guess this tool would be ideal, BTW Happy Birthday. Karl
post #12 of 17 (permalink) Old 07-08-2011, 11:56 PM
Member
Styrofoam_Guy's Avatar
I would have to go for the badger paint mixer. Great little tool.
The Dremel tool with the various attachments is a must.
There are other power tools but one that I use as often and as much.
Styrofoam_Guy is offline
post #13 of 17 (permalink) Old 07-09-2011, 12:24 AM
Modeler's Brand
Model Man's Avatar
I've burned the motors on two dremel XP's (Don't have the recepits for warranty work) and now have a 4000 (the XP was better), but I think a stylus would be a nice treat to have for smaller work.
The dremel drill press has been most useful when drilling many small holes in flat plastic -and useful for holding a grinding wheel steady while I gently apply a part/piece to it. The dremel "mini-buzz saw" attachment has been a godsend and the reciprocating saw blade is a nice one to have too -but that is more for minor workbench mods than models.
The Tamiya Handy Drill (~$30 model kit!) is PRIME for low power drilling that won't melt plastic. DOwnside is the lack of available collet sizes.
Then I have a regular sized power drill replete with bits, a drill bit sharpener (I haven't tried yet), a Makita orbital/palm sander, soldering station, air compressor with tank, plenty of power strips, lots of lights and fans as well. Can't forget that side of the power equation!
Oh yeah, I just got a mini paint blender and a 'plastic sealer' that looks to be great for resealing open plastic parts bags in a jiffy. I'll review those soon on my youtube.
What tools would be nice? The dremel band saw table looks pretty cool. Some of the stuff here sounds neat too. So many tools, so little money.
I'm not a Model Man. Not a savior or a saint. Imperfect in a word, make no mistake.
-King Crimson
Model Man is offline
post #14 of 17 (permalink) Old 07-09-2011, 01:37 AM
Top Dog
I'm sure I'll leave something out, but here goes:
- Variable-Speed Dremel Mototool(s) with tons of accessories
- Drill Press with laser guide
- Table saw
- Mini table saw
- Band saw
- Scroll saw
- Router
- Belt/Disc sander
- Bench grinder
- Tube bender
- Vise(s)
- Palm Sander
- Airbrushes
- Compressor/Tank
- Paint Shaker
- Soldering Irons (gun and pencil) with stands and accessory tips
- Mini torches
- Lathe
- Mini Lathe
- Assortment of clamps
- PE folder
- Vacuum formers
- Choppers I, II, and III
- Lazy Susan
Assorted tools (sprue flush cutters, flat and Philips screwdrivers, jewelers screwdrivers, security screwdrivers, X-Acto knives and blades of various types, razor saws and mitres, X-Tra Hands with Magnifiers, X-Acto Compass & Circle Cutter, eye loops, shop vac, clamps of various sizes and strengths, hammers, pliers, anvil, hand saws, dental instruments, dental mirrors, assorted files of different sizes and shapes, sanding blocks of various sizes and shapes, scissors, tin snips, sanding strips, etc.)
Various types of paint brushes, sponges, and rubber bits of every size and shape.
Aside from hobbyshops, Home Depot, Michaels and Harbor Freight are a modeler's best friends.
This is what happens when you collect this and that over the course of several decades!
Trek Ace is offline
post #15 of 17 (permalink) Old 07-09-2011, 09:55 AM Thread Starter
HobbyTalk Pro
Interesting comments, guys. I'm enjoying this thread.
Do any of you get the Micro Mark catalog? I sit and drool over that thing for hours every time a new one comes in. I'd need a hobby room 3x what I have to hold all the things I'd like to order from them.
Fozzie is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
