Short course 17.5 Brushless help. - HobbyTalk
Reply
post #1 of 21 (permalink) Old 05-03-2010, 12:15 PM Thread Starter
Member
big boy 37's Avatar
I have Traxxas slash an SC10 with Velineom Brushless speed controls in both of them with stock brushed motors. Looking to put 17.5 brushless motors in them to run on the dirt tracks. What are you guys an girls out there running an are you using the Velineon speed control? Thanks Ron.
big boy 37 is offline
Sponsored Links
Advertisement
post #2 of 21 (permalink) Old 05-03-2010, 02:56 PM
HobbyTalk Pro
snwchris's Avatar
Location: ARCS / Rock Mafia Racing / NemoRacing USA / Agama
Use the Velineon brushless motor, especially if you can get one from a 4x4 model. it'a rated at 3500kv which would be better (faster) then the 17.5 depending on what your going for.
If your looking to stay in stock class then yea the 17.5 is what you would need, otherwise the you can run 13.5 in it as well.
Chris
snwchris is offline
post #3 of 21 (permalink) Old 05-03-2010, 05:52 PM Thread Starter
Member
big boy 37's Avatar
Thanks. Yes the Velineon motor is fast. Yes i am looking to stay in the stock class but tiered of buying the brushed motors. Will a 17.5 brushless motor from a diffrent brand work with that speed control? If so what is a good one? Or do I need to get a new set up?
post #4 of 21 (permalink) Old 05-03-2010, 07:38 PM
Member
You can try the 17.5 on your esc and just don't hook up the sensor cable. But you will find out real quick a major cogging issue. Offroad does not need the turbo or timing crap. Once you go sensored you won't look back.
speedster1919 is offline
post #5 of 21 (permalink) Old 05-03-2010, 10:18 PM
Elder Statesman
scramblerman's Avatar
ive ran a 13.5 novak ballistic with the sensor wire connected on the velenion speedo and had no problems with it
scramblerman is offline
post #6 of 21 (permalink) Old 05-03-2010, 10:46 PM
HobbyTalk Pro
snwchris's Avatar
If your gonna spend the money on brushless your better off moving up to MOD Corr and get the 13.5 or Velineon. I'm not sure how the stock class is in your area. Some of the tracks I've been to, don't usually get enough stockers to run a class so they all run in the Mod Corr class. Unfortunately it also mean more upgrades to be competitve, but just a thought.
Chris
snwchris is offline
post #7 of 21 (permalink) Old 05-06-2010, 10:10 AM
Elder Statesman
bustedparts's Avatar
Send a message via Yahoo to bustedparts
I am runing a fantom 17.5 with a tekin rs pro in my sc10 and my truck is one of the fastest at the track. Lots of punch!
bustedparts is offline
post #8 of 21 (permalink) Old 05-10-2010, 08:21 PM
Elder Statesman
RCDawg83's Avatar
Quote:
That would be a sweeeet setup but a little pricey. There are lots of great deals on GTB's nowadays. They have always worked very well for me in off road applications.
RCDawg83 is offline
post #9 of 21 (permalink) Old 05-10-2010, 08:29 PM
Elder Statesman
grunt66's Avatar
I run novak XBR with a Fantom 13.5 in my truck great set up and one of the fastest at my local track just have to gear it right
grunt66 is offline
post #10 of 21 (permalink) Old 05-10-2010, 09:37 PM
Elder Statesman
yes also i have my truck geared 26/71
post #11 of 21 (permalink) Old 05-12-2010, 11:02 AM
Member
I run an orion 17.5 vortex and mamba max pro and love it very controllable power on the track and very fast!
bigmike22 is offline
post #12 of 21 (permalink) Old 05-14-2010, 08:49 AM
Elder Statesman
dougglo's Avatar
I have just bought the same. Can you share set up?
dougglo is offline
post #13 of 21 (permalink) Old 05-16-2010, 02:29 PM
Elder Statesman
420 Tech R/C's Avatar
Quote:
Hobby wing makes a 17.5 sensorless motor that will work with the VXL speedo.Check with your RD first and make sure the sensorless 17.5 will be legal to run.If its a go the motor is 39.99 @ hobbypartz.com...By the way the VXL will run a sensored motor- look in the front under the on/off/program button.There is a sensor port there with a cap over it.I ran a VXL speedo with a novak 17.5 for quite a while after I first went brushless.
420 Tech R/C is offline
post #14 of 21 (permalink) Old 05-26-2010, 02:23 PM Thread Starter
Member
big boy 37's Avatar
Thank you all for your input. Are any of you running the new Novak Ballistic 3S system an if so what gearing are you using.
post #15 of 21 (permalink) Old 05-26-2010, 09:21 PM
Member
According to gear chart-SC10 with 17.5 novak is 87-30pinion
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
