How to Hop up AW chassis - HobbyTalk
post #1 of 8 (permalink) Old 04-29-2009, 08:57 AM Thread Starter
Member
I got a AW chassis with a Duke of Hazzard car. Also getting a four gear I believe with the S'cool bus. I am wanting to know how to hop these up for drag racing. Thank you. Jody
smartresins is offline
Sponsored Links
Advertisement
post #2 of 8 (permalink) Old 04-29-2009, 10:10 PM
Member
Soooooo many ways. Change rear axle....to one with more teeth on the crown gear.
Silicone tires for better traction. I swap out the stock pick up shoes and replace them with nos silver pick up shoes from AFX non-magnetraction (available on ebay).
jeremy1082 is offline
post #3 of 8 (permalink) Old 04-29-2009, 10:44 PM
copperhead71's Avatar
Thumbs up
Are the wide shoes that come on aw reccomended for anything!
copperhead71 is offline
post #4 of 8 (permalink) Old 04-30-2009, 01:48 PM
dlw
HobbyTalk Pro
The silver shoes are for better conductivity, which is big in drag racing. The standard AW shoes are excellent for 'road' racing and routed tracks.
dlw is offline
post #5 of 8 (permalink) Old 04-30-2009, 06:37 PM
Member
The n.o.s. silver shoes are like switching from a 2 barrel to a 4 barrel carb....the car is just more lively. There is an instant difference. The silicone tires are important too...more power is useless if all you do is spin the tires.
You can also "shim" the magnets...a little tape or paper behind the motor magnets to bring them a little closer to the armature (every little bit helps).
The newer AW cars are pretty good out of the box but you can always improve them.
As for the crown gear...I think a 15 tooth gear is stock, but there was a 19 tooth "hop up" gear available (some n.o.s. still available on ebay) for AFX. I have some that I have managed to swap in a 22 tooth gear from a Tomy Turbo and a 25 tooth gear from a G Plus. The more teeth on the crown gear, the better take off power the car will have but you will give up some top speed.
Some arms are higher revving but less low end torque and need a more high performance gear set up (quadralams) and some are slower revving but alot more low end torque (blue drag arm) and are fine with more mild gearing. I like to mix & match and have an AFX Tractor-trailer with the torquey blue drag arm and ultra low gears (25 tooth) so that it handles any extra weight with no problem.
post #6 of 8 (permalink) Old 05-02-2009, 09:36 AM Thread Starter
Member
I am wondering where I can buy a drag armature for the AW 4 gear chassis? Also Wanting to know where to buy drag armatures and metal gears for the Aurora/tomy super G chassis.Also, say on a 22 foot track, 5 foot of wich is braking area, how would I be able to figure out what armatures/gears I would want? Thanks. Jody
post #7 of 8 (permalink) Old 05-02-2009, 12:23 PM
Lifetime Member
resinmonger's Avatar
Quote:
Smartresins,
Here are two builders of mondo cool custom pancake arms.
Alan Galinko:
http://agg.fsmra.com/
DC HO Motors:
http://www.geocities.com/dc_ho_motors/
For custom in-line Tomy arms and gear goodness, try Scale Auto' BSRT parts:
http://www.scaleauto.com/bsrt/index.htm
Or try Wizzard for in-line Tyco arms and gears suitable for Tomy chassis:
http://www.wizzardho.com/
Also try Slot Tech for in-line Tyco arms and gears suitable for Tomy chassis:
http://slottech.net/default.aspx
For awesome drag bodies, check out the brothers Mead:
http://www.gm454dragbodies.com/index.html
http://www.tm427dragbodies.com/index.html
These are mostly for T-Jet chassis. Mostly. But the Meads are starting to make bodies for AFX and Tyco chassis as well. Besides, it may be time for you to embrace your inner T-Jet lust. Don't be embarrased about it, most of us have it as well.
This should get you in the right ballpark. Drag On!
Hutt
Last edited by resinmonger; 05-02-2009 at 12:35 PM. Reason: be addin' mo betta info yo!
resinmonger is offline
post #8 of 8 (permalink) Old 05-02-2009, 09:11 PM
Member
I got mine from ebay. There always seems to be some there. I have also bought some custom made pancake arms from ebay.
I like the blue drag arm...lots of low end torque and not bad revver too.
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
