Electronics help for RC pit trailer.... - HobbyTalk
post #1 of 2 (permalink) Old 01-14-2016, 10:56 AM Thread Starter
Member
SoAzRC's Avatar
Okay. I need some help and advice on wiring my "new" pit trailer. I run Friday night dirt oval at Stateline RC in Fremont Indiana and bought an old "pop up" camper, removed the beds and canvas, and now need to set it up. Main question has to do with efficiency. I have used two deep cycle 12v batteries in the past to provide power for my chargers and a small inverter for charging my LED lights. This has worked well and quiet. I have a Protek 40 power supply that I use at home that allows me more current to the charger. Should I buy a bigger inverter to power the power supply and 110v LED tube lights? Seems I'm going from LV to HV back to LV. I really don't want to use a generator, but will if that's the best option. How about longevity of the 12v charge, i.e.: how long will a charge last in hours... Help please.
SoAzRC is offline
Sponsored Links
Advertisement
post #2 of 2 (permalink) Old 01-14-2016, 03:26 PM
HobbyTalk Pro
chuck_thehammer's Avatar
first .. you may know.. all auto/watercraft Batteries... you NEVER discharge below 50 percent of battery capacity .
best plan.. a 12 volt charger for your RC stuff... the 12 to 120 to 8 or so .. as you stated in NOT Good. do-able but not good..
more batteries... or a generator... just keep in mind.. some generators do not have TRUE "AC" sinewave... but modified square wave.. and will/can make some electronic equipment go NUTS....
as a backup on my Camper.. I have a 400 watt inverter running a 32in flat screen TV AND a satellite box.. just fine.. From a 650 amp hour 12 volt battery.
but will NOT run a stupid electric blanket.. for the wife. blanket will not turn on from inverter.. go figure. but works fine from the wall 120...
and YES.. inverter and generator can & do make modified square wave.... and higher end units make True sinewave..
NO way of telling till you TEST them.
chuck_thehammer is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
