6V 5Ah lead sealed battery charger - HobbyTalk
post #1 of 6 (permalink) Old 06-14-2010, 04:06 PM Thread Starter
Member
I have a spot light that uses a 6V 5Ah lead sealed battery. I have lost the charger. What power charger(volts and amps) should I get to charge my light?
nolen01 is offline
Sponsored Links
Advertisement
post #2 of 6 (permalink) Old 06-15-2010, 10:03 AM
Member
GhostKnight's Avatar
Get a charger for 6V-Lead-Batteries (actual voltage should be somewhere at 6.7 to 6.9 volts, roughly; the companies who make the chargers can usually be trusted to get it right ).
The current for your battery should be at 0.5 or 0.6 amps, resulting in a 8 - 10-hour charge cycle.
I would recommend a charger with automatic shutdown, so your battery won't get damaged. When the charger doesn't have that feature, make sure that the battery isn't hooked up too long; the duration of the charge cycle normally is the capacity (5Ah) divided by the current (p.e. 0.5A) -> 10 hours.
Greets
Tom
GhostKnight is offline
post #3 of 6 (permalink) Old 06-15-2010, 05:35 PM Thread Starter
Member
You are the first one who has ever explained it. Thank you.
nolen01 is offline
post #4 of 6 (permalink) Old 06-17-2010, 08:19 AM
Member
No problem!
Just a few more pointers:
- don't use a higher current (unless you know exactly, what you're doing), the battery might overheat while charging and explode.
- while charging, check the battery's temperature. make sure it doesn't get too hot.
- The more expensive the charger, the more sophisticated it should be (some have features like battery regeneration, auto-shutdown, overheat shutdown,...). Just make sure you don't by the best, if you just use it twice a year
greets
tom
post #5 of 6 (permalink) Old 10-26-2010, 11:27 PM
HobbyTalk Pro
lordraptor1's Avatar
Send a message via MSN to lordraptor1 Send a message via Yahoo to lordraptor1
if you happen to have a venom pro charger plus you can charge your lead acid battery with that, it is capable of charging:
1-27 cell Ni-Cd/Ni-Mh packs
1-8 series LiPo/LiIon packs
2 to 36V lead acid batteries
so it would be a good investment as it works for a variety of batteries
lordraptor1 is offline
post #6 of 6 (permalink) Old 05-29-2012, 08:48 PM
Member
works great have used it many times
stew215 is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
