Voltage Regulator - HobbyTalk
post #1 of 11 (permalink) Old 01-20-2011, 12:21 PM Thread Starter
Member
Ovalhead's Avatar
Voltage Regulator
Will a residential light dimmer switch work for a voltage regulator for the 22volt wall power units in 1/64 ?
Something tells me it ain't that simple............
Cliff
Ovalhead is offline
Sponsored Links
Advertisement
post #2 of 11 (permalink) Old 01-20-2011, 12:30 PM
LED Burner Outer
slotcarman12078's Avatar
I think I read somewhere on here a dimmer switch won't work. There is something though that will. From what I've read, a variable router speed control will work. This is a finished unit, ready to use. Plug your power pack into the control, and plug the control into the wall.
slotcarman12078 is offline
post #3 of 11 (permalink) Old 01-20-2011, 01:04 PM
Elder Statesman
Rolls's Avatar
Cliff - See if this thread from last March helps...
Light dimmer for variable voltage
Rolls is offline
post #4 of 11 (permalink) Old 01-20-2011, 01:07 PM
Elder Statesman
Nope tried it a long time ago. Not enough wattage draw from the power pack. They do make dimemrs for low voltage lighting rated at 300 watts but those are @ $35 so might not be affordable.
Slott V is offline
post #5 of 11 (permalink) Old 01-20-2011, 10:13 PM
Lifetime Member
I've been running wallwarts/battery chargers on cheap household dimmers for years,use them for all sorts of things,car break-ins/homemade dyno's etc.,never had any problems yet.
Wire them into a cheap extension cord and plug your wallwart into the cord.
They aren't what i'd call a good quality way of doing things,but it's cheap and works pretty well for what they are
Here's a pretty decent article on cleaning up a wallwarts output
http://www.dxing.info/equipment/wall_warts_bryant.dx
Hornet is offline
post #6 of 11 (permalink) Old 01-20-2011, 11:48 PM Thread Starter
Member
Ovalhead's Avatar
Great replies racers, now I have some reference to what I'm trying to do, hopefully.
Again thanks,
Cliff
Ovalhead is offline
post #7 of 11 (permalink) Old 01-21-2011, 12:38 AM
Elder Statesman
SwamperGene's Avatar
Send a message via AIM to SwamperGene
That's a great link. I made up a little variable supply using a wall-wart...probably 5 years ago. I chucked it a month or two ago cuz one of the legs on a cap came loose. Now I find myself lookin' for the stupid thing all the time
SwamperGene is offline
post #8 of 11 (permalink) Old 01-21-2011, 01:54 AM
LED Burner Outer
I stand somewhat corrected!! I do remember that thread, it must have been one of those early morning reads for me. Sorry if I misinformed you!!
post #9 of 11 (permalink) Old 01-21-2011, 02:45 AM
Elder Statesman
Rolls's Avatar
Great link, Hornet! Good wall wart info! Thanks for posting it.
Rolls is offline
post #10 of 11 (permalink) Old 01-21-2011, 02:51 AM Thread Starter
Member
Ovalhead's Avatar
No apology needed, I'm happy for just your participation.
These forums are my only way to learn about my passion.
Cliff
Ovalhead is offline
post #11 of 11 (permalink) Old 01-21-2011, 08:14 AM
Lifetime Member
This guys resistor values are a little more realistic then other sites have them.
If you use the other voltage regulator diagram done by Dumas (Rich D) it won't work for HO,his resistor values are a bit out to lunch for HO,his resistor values might work okay on 1/32 but won't work on HO
If you throw a decent sized cap on the average wallwart it'll gain close to 5 volts or more on it's output,something like a 35volt 3300uf cap will really wake one up.
The cap will be marked with a stripe,or a negative sign (-) for the negative side of it,if the caps not marked usually the longer wire leg out of the cap is the positive
http://www.slotcarcorner.com/pages.php?pageid=38
Hornet is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
