Rebuilding a 27hp Kohler engine ch740 - HobbyTalk
post #1 of 3 (permalink) Old 11-05-2011, 09:40 PM Thread Starter
Member
Hello all I am new to this forum. The pressed on Cam gear on the crank shaft has cracked and now free spins on the crank. I am woundering what could cause this? I have torn down the engine and both of the intake rods for the lifters are warped slightly. I cleaned the valves with a wire wheel and also laped the surface.. everything lookes good. I am thinking of putting on a new set of rings while I have it all torn apart. I am planing on using standard rings and am woundering what type of honeing I should do?? Probably a high grit honeing? Just to deglaze the cylinder? I am a little nervouse with this being my first time and would apreciate any input you fine folks could give me
Thanks in advance
Lawns4Life is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 11-06-2011, 09:00 AM
Top Dog
30yearTech's Avatar
You can download the Kohler service manual for your engine at the Kohler website. It will give you a lot of info and specs for the engine. My guess on the bad timing gear is perhaps it was damaged in the original installation as there is no real reason for the gear to fail in normal use with proper engine maintenance.
www.kohlerplus.com for the manual, just enter as a guest.
30yearTech is offline
post #3 of 3 (permalink) Old 11-07-2011, 06:59 AM Thread Starter
Member
Thanks for the reply, Yes I do have the manual. My question is more along the lines of since I already have to replace the crank, should I also put a new set of rings on? The cylinders look great with no scoring or pitting. I can still see the cross hatch pattern on the cylinder walls. The motor has close to 2000 hrs. on it. Also what type of honing should I do?
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
