Toro model 20622 mower - HobbyTalk
post #1 of 10 (permalink) Old 05-08-2010, 03:45 PM Thread Starter
Member
Bryanser's Avatar
Does anyone know how to correctly install the blade belt on this mower. It has a spring loaded assembly. Or where I can find a free service manual online for this mower.
Thanks.
Bryanser is offline
Sponsored Links
Advertisement
post #2 of 10 (permalink) Old 05-08-2010, 04:23 PM
Top Dog
30yearTech's Avatar
All you need to do is remove the blade and the lower portion of the clutch by removing the large nut that attaches it to the engine crankshaft. Then remove the bolt holding the idler pulley on. The belt will slip off and the new belt installation is just the reverse of removal. You don't really have to remove the large nut from the crankshaft to do this, I just find it easier.
30yearTech is offline
post #3 of 10 (permalink) Old 05-09-2010, 03:52 PM Thread Starter
Member
Bryanser's Avatar
I was attempting to replace both belts. I removed the idler pulley assembly and now while reassembling everything the idler pulley contacts the flywheel. Since the idler pulley assembly is spring loaded I assume the spring must be under tension when installed, but I do not know how much tension is required, to prevent the assembly from contacting the flywheel.
Thanks.
Bryanser is offline
post #4 of 10 (permalink) Old 05-09-2010, 05:46 PM
Member
Quote:
Thanks.
You can download a service manual here:
http://toro.com/index.html
Just click "homeowners parts" type in model number, then click on manuals.
indypower is offline
post #5 of 10 (permalink) Old 05-09-2010, 09:37 PM
Top Dog
30yearTech's Avatar
Thanks.
The assembly contacts the clutch drum so as to stop the blade from turning when the clutch is disengaged. When the clutch is engaged the assembly pulls away from the drum and applies tension to the belt, to engage the blade drive.
If you removed the idler pulley bracket from the mower deck, then the spring tension on the assembly will have to be reset, otherwise it should still be alright.
post #6 of 10 (permalink) Old 05-20-2010, 04:00 PM Thread Starter
Member
Bryanser's Avatar
Apparently the .pdf file is damaged and can not be opened. Would you please send it again?
Bryanser is offline
post #7 of 10 (permalink) Old 05-20-2010, 04:51 PM
Top Dog
30yearTech's Avatar
Are you talking about pdf file I posted???
post #8 of 10 (permalink) Old 05-20-2010, 09:21 PM
Member
junebug1701's Avatar
The PDF downloaded and opened fine for me.
junebug1701 is offline
post #9 of 10 (permalink) Old 05-21-2010, 04:37 PM Thread Starter
Member
Bryanser's Avatar
Hank: Yes I am talking about the pdf file you posted.
I tried to download the file again and couldn't. Can you attach it as an email directly to me? brysm607@aol.com
Thanks
Bryanser is offline
post #10 of 10 (permalink) Old 05-21-2010, 06:35 PM
Top Dog
30yearTech's Avatar
Thanks
Don't know why you can't view it. I sent the manual to your email address.
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
