Tecumseh Compression Release - HobbyTalk
post #1 of 7 (permalink) Old 08-06-2009, 04:48 PM Thread Starter
Member
TVXL220-157246C 10 HP Tecumseh with automatic compression release. The engine starts and runs good but when it get a load on it, it loses power and dies. Here is my question. Can the ACR get stuck and not let the exhaust valve seat at high RPM? Or will a valve job fix it?
Thanks
Mike
mf223 is offline
Sponsored Links
Advertisement
post #2 of 7 (permalink) Old 08-06-2009, 07:20 PM
Top Dog
30yearTech's Avatar
It would be possible, although I have never run across it. Even if it was stuck, it should not make a tremendous difference, as the rpm's increase the amount of time the valve would open should not be enough to create a substantial loss of power. There are bump type compression release that never disengage.
A lean mixture setting can also cause a loss of power, are you sure your issue is low compression?
30yearTech is offline
post #3 of 7 (permalink) Old 08-07-2009, 03:05 PM Thread Starter
Member
When I took the head off and turned it by hand the exhaust valve would open back up slightly and would not appear to seat until after the piston would travel a little over half way up on the compression stroke. Just didn't look right to me then found out about the compression release. The exhaust valve looks to me like it's just not seating well.
mf223 is offline
post #4 of 7 (permalink) Old 08-07-2009, 09:51 PM
Member
Sounds like a sticky valve stem. Maybe pull the plug and spray carb cleaner around the valves while you are cranking it. Pull the muffler and spray the exhaust valve stem with carb cleaner. Run some marvel mystery oil in gas and oil. If all else fails, pull the head and check the valve and seat. Run a card around it to clean up any piece of carbon. Maybe put a little valve lapping compound in there and turn the valve some to clean up the seat if there is a seating problem. Then spray away all the excess compound.
Post back with what works.
bc11 is offline
post #5 of 7 (permalink) Old 08-15-2009, 11:18 PM Thread Starter
Member
Did a valve job and replaced the rings. Has more power now but engine still misfires a little. Also had to reset the air gap on the armature.
mf223 is offline
post #6 of 7 (permalink) Old 08-15-2009, 11:36 PM
Elder Statesman
justin3's Avatar
Send a message via AIM to justin3
If it is misfiring, I would look into a partially sheered flywheel key or a blockage in the carburetor.
justin3 is offline
post #7 of 7 (permalink) Old 08-16-2009, 11:06 PM
Member
Turning the motor over by hand is not fast enough for the compression release (ACR) valve to work the way your thinking. Only at a higher RPM will this disengage fully for it to seat the valve fully. Maybe above 400 RPM the ACR will fully open then the valve fully seats. If your valve is sticking open you will hear it "pppfffftttt" through the exhaust on that stroke while running. It will sound different then normal. I agree with justin3 on his suggestions. Carb is easiest to get to so I would do that first, then look at flywheel key.
dj722000 is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
