Cub Cadet tractor flywheel removal - HobbyTalk
post #1 of 2 (permalink) Old 02-07-2009, 08:35 PM Thread Starter
Member
Guys,
I have a Cub Cadet lawn tractor model 2145 in my shop for service. I dont have to do this yet, but may in the future...
How do you remove the flywheel on one of these tractors? it has a horizontal Onan engine on it. one side of the flywheel obviously is against the engine and the other side of the flywheel has a shaft bolted to it that runs the hydro. transmission.
if you had to remove the flywheel how do you do it ??
Thanks for the info.
Mark
Dimark1009 is offline
Sponsored Links
Advertisement
post #2 of 2 (permalink) Old 02-09-2009, 10:52 PM
Member
Do you have a Lawnboy plug to hold piston from moving? I'd give that a try. That will hold piston and crank from moving so you can remove nut from flywheel without crank moving. I'd turn the flywheel counterclockwise by hand till plug stops piston movement then remove nut.If piston doesn't line up with sp.hole then I try a screw driver with a piece of hose over it ,so it doesn't scare top of piston. HTH
bser is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
