Kohler engine blows black smoke on startup - HobbyTalk
post #1 of 3 (permalink) Old 08-31-2008, 04:48 PM Thread Starter
Elder Statesman
justin3's Avatar
Send a message via AIM to justin3
Question Kohler engine blows black smoke on startup
I've got a 2004 John Deere LT160 lawn tractor with the Kohler Commando 16hp engine. Ever since a year after we got it every once in awhile when me or my dad go to start it, it will start hard and blow puffs of black smoke out the exhaust. This only occurs after the tractor has run for awhile and tends to randomly happen. There is no pattern to when it occurs. For example today I stopped and started the engine about 11 times and the smoke only occurred once when i went to start it.
Anyone got any ideas? Someone told me this was normal for Kohler engines.
justin3 is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 08-31-2008, 08:17 PM
Top Dog
30yearTech's Avatar
I don't think it's all that unusual, but I would check the choke just to be sure. Make sure the choke opens all the way and the choke plate is not partially closed (even just a little) or it can get sucked closed. The choke on these engines has a spring and can be adjusted to different settings, underneath the plastic spring housing is a guide that runs on a small pin in the top of the carburetor. Dirt can accumulate in this guide and keep the choke from opening completely. If the choke plate will not open all the way, this will need to be cleaned.
30yearTech is offline
post #3 of 3 (permalink) Old 08-31-2008, 10:35 PM Thread Starter
Elder Statesman
justin3's Avatar
Thanks 30year, I will check it out tomorrow!
justin3 is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
