12 hp Briggs and Stratton riding mower engine trouble - HobbyTalk
Reply
post #1 of 24 (permalink) Old 07-17-2008, 05:16 PM Thread Starter
Member
I have been trying to fix my grandmas riding lawn mower. My uncle was using it when it stalled and it hasn't started since. I'll try to explain everything to the best of my ability but I'm only 16 so my knowledge on the topic is very minimal. I appreciate your patience. Unfortunately, I don't have any more information on the engine at this time than that it is a 12hp Briggs and Stratton. The carburetor also sports the Briggs and Stratton logo. The engine is turning over correctly and it is getting a spark. I also know that the fuel and air filters are not the problem. I know that fuel is getting to the carburetor so I took apart (at least as apart as I could get it). I removed it from the engine and removed the float bowl. Both the float and the main jet (at least I think that's what it is) that comes up the middle of the carburetor seem to be functioning. I also blew compressed air through the whole thing. Nothing seems to help. I can't even get the engine to sputter. Another thing that's puzzling me, I noticed a tube attached near the air filter that led to a plate on the side of the engine block. I removed the plate and there were two metal rods with springs around them. There was some oil in the chamber but it didn't seem like it would fill with oil during normal operation. I initially thought these were valves but I didn't think lawn mower engines had valves. Perhaps it is chainsaw engines I'm thinking of. If this engine does have valves, perhaps those are malfunctioning? Anyway, I'm out of ideas. I'd like to avoid rebuilding the carburetor unless I know that will solve the problem as that seems to be complicated and I run the risk of making another problem. I also don't know that I would be capable of taking apart the block. I've reached a dead end and appreciate any suggestions.
spiderdan is offline
Sponsored Links
Advertisement
post #2 of 24 (permalink) Old 07-17-2008, 06:41 PM
Top Dog
30yearTech's Avatar
If it was running and just stalled, then I would not think you need to go too deep into the engine, at least not yet.
Those are the valves you are looking at, and the part you removed with the tube is the oil breather. Slowly rotate the engine around and you should see the valves operate.
Have you checked to see if you have any compression in the engine?
30yearTech is offline
post #3 of 24 (permalink) Old 07-17-2008, 06:59 PM Thread Starter
Member
I'm not sure what you mean by compression in the engine, so to answer your question no. How can I go about checking for this. Also, if compression is the problem what would need to be done to resolve this issue? By the way, what is the purpose of the oil breather? I didn't think the oil needed to be in contact with air. Thank you for the reply!
post #4 of 24 (permalink) Old 07-17-2008, 08:12 PM
Top Dog
30yearTech's Avatar
http://www.hobbytalk.com/bbs1/attach...1&d=1216339138
Pg76.pdf
This may help a little with your understanding of how this engine operates.
The oil breather is there to vent pressure from the crankcase and produce a slight vacuum when the engine is running, it's connected to the carburetor so that any oil vapor that may escape is drawn back into the engine through the carburetor intake. Some engines simply vent it back to the atmosphere.
A simple compression test for which no tools are required is to spin the engine over at cranking speed, then watch the flywheel on the engine as it slows to a stop, if it stops abruptly or bounces back in the opposite direction then there should be sufficient compression for the engine to start and run. The best way to check for proper compression is with a leak down test, but this requires special testing tools.
There is a wealth of information available in the FAQ section of the Briggs and Stratton website.
post #5 of 24 (permalink) Old 07-17-2008, 09:47 PM Thread Starter
Member
Thanks for the information 30yearTech. I checked out the Briggs and Stratton website. If compression is the issue, do you expect that I'll need new valves, gaskets etc., or will it most likely just be a jam? Also, I'm not sure I have the proper tools to remove the valves, such as a valve spring compressor. I think the guide on the Briggs and Stratton website also mentions a precise measuring instrument. Will I need to drain the oil from the mower to get to the valves? Thanks again for all the advice!
post #6 of 24 (permalink) Old 07-17-2008, 10:14 PM
Top Dog
30yearTech's Avatar
If it is a compression issue there may be several different things that it could be.
It could be a stuck valve, bad valve seat, foreign object caught in the valve, carbon build up, and may not be the valves at all. You do not need to drain the engine oil to work on the valves, but you do need special tools to reinstall the valves if you take them out, and you should get an automotive feeler gauge to check the valve clearances even if you don't take them out.
post #7 of 24 (permalink) Old 07-17-2008, 10:30 PM Thread Starter
Member
Hopefully I wont have to remove the valves, I have a feeling that's wishful thinking though. If this were carbon buildup, wouldn't this have happened gradually rather than all of the sudden? If the problem isn't the valves I would assume it would most likely be a bad seal near the ?cylinder head? (the part the covers the piston and valves) or the spark plug, is this correct? Once again, I really appreciate all the help.
post #8 of 24 (permalink) Old 07-18-2008, 09:07 AM
Top Dog
30yearTech's Avatar
Well I have seen a piece of carbon build up, chip off and get under a valve, so it's possible, but you won't know if that it without an inspection.
The first thing I would try is a new spark plug, also do the basic compression test. Make sure you have spark to the plug as well.
If and when you take the cylinder head off, you will need a new gasket (seal) before you reinstall the head.
post #9 of 24 (permalink) Old 07-18-2008, 01:11 PM Thread Starter
Member
Hopefully it is just a piece of carbon build up, that would probably be easy enough to fix. I checked the spark and it was fine. I also tried a new plug. I probably won't get a chance to look at it again until early next week, Monday maybe. I'll be sure to post results. Thanks!
post #10 of 24 (permalink) Old 07-18-2008, 11:28 PM
Member
I think you're getting way too far ahead, worrying about valves. There are simple diagnostic steps you should go through before tearing into stuff.
You've already done the first: check for spark. So if the spark is fine, the next thing to check is fuel - is any getting into the cylinder? Try starting the engine, allowing it to turn over several times, then remove the spark plug and inspect it. If it's dry, and doesn't smell strongly of gasoline, then maybe fuel isn't getting through the carb. At this point I would try starting fluid, or you can add a half teaspoon of gasoline directly to the cylinder through the spark plug hole; reinstall the plug and try starting again. If it starts, then dies, you have a fuel-supply problem - gasoline isn't getting from the carb to the cylinder.
There are three or four possible reasons for that: Gas tank cap vent plugged; fuel line plugged; fuel filter plugged; carburetor dirty. Find the fuel line coming from the gas tank, and pull it off the carburetor nipple. If gas doesn't flow out, then it's the fuel line or fuel filter. If it drips unsteadily, maybe it's the gas tank cap vent. If gas flows out steadily, the problem is in the carb, so the next step would be taking that off and disassembling it for a thorough cleaning. Only if that fails would I start looking at the intake valve.
It's very common for a small bit of gunk to get into the float valve or the main jet on these carburetors and stop the flow of fuel. Even a very tiny particle can do it.
If fuel is getting to the cylinder but it still won't start, then maybe the gas is bad (water in it) or maybe the plug isn't sparking after all. Or something is blocking the air intake, so the gas can't get mixed with air to ignite; but usually if that's the case it will at least cough before dying.
Albionwood is offline
post #11 of 24 (permalink) Old 07-19-2008, 02:37 AM Thread Starter
Member
Thanks for your response Albionwood. I have already tried disconnecting the carb and fuel flowed through the filter quite well. I actually drained the whole gas tank like this with the fuel cap on (through some of the draining process, I took it off at some point to check progress.) This makes me think the cap isn't the problem. I also tried starting it with the cap off. As for the carb, the float valve seemed fine and the main jet was not clogged, but I am no expert on carburetors. Its possible I missed something. Are there any other jets than the main? Also, I ran compressed air through the carburetor intake and it was expelled from the hole where the float valve was. I'm assuming this means it is clear and when the valve is open fuel just comes out around it?
post #12 of 24 (permalink) Old 07-19-2008, 10:55 AM
Member
OK, you've eliminated all problems upstream from the carburetor, but it is still a possible suspect. Compressed air can get through where fuel can't, because the gas does not have much pressure behind it. If the float valve sticks just a little bit it can be enough to prevent fuel flow. I've had to disassemble and clean a carb two or three times, each time believing it was pristine, before it would work. The B&S book on "Small Engine Care & Repair" shows how to do this in good detail. There might be something online as well.
How did the engine behave before it died? Was it "hunting and surging," going up and down in speed, or did it run just fine and then suddenly stop? "Hunting" is a typical symptom of a dirty carb or bad gas. But if it was running fine and suddenly quit and never coughed again, that might point to something more serious.
Try this: Remove the wire from the spark plug. Take off the air filter and filter housing. Cover the air intake with your hand, and manually turn the engine flywheel through at least one complete rotation. You should feel resistance as compression builds in the chamber, then it suddenly gets easier to turn as the exhaust valve opens; and at one point when the intake valve opens you should feel suction on the intake tube.
If there's no suction on the intake at any time, then the intake valve probably isn't operating. If you don't feel compression building and releasing, then maybe the valves aren't working (one or both is stuck open or leaking slightly), or there's a leak (blown head gasket or cracked head), or worse (piston connecting rod broken). I'm not expert enough to help with any of that - maybe somebody else here can step in.
post #13 of 24 (permalink) Old 07-20-2008, 01:26 PM Thread Starter
Member
Thanks for following up albionwood. As I said, my uncle was using it when this issue arose so I can not tell you first hand what happened. According to him, it was just fine but suddenly stopped. No sputtering or anything. I will give your suggestions a try.
post #14 of 24 (permalink) Old 07-21-2008, 04:49 PM Thread Starter
Member
I got a chance to look at the engine today and will post my results. Using 30yeartech's method of compression testing the flywheel did not "bounce back" the first couple times I tried this test but started bouncing back after the third try. Using Albionwood's compression testing method I noticed slight increases and decreases in resistance but never noticed any sucking. While I had the air filter off I did notice some liquid under it. I thought it was gas but I suppose it could be oil from the oil breather. Anyway, I decided to take the cylinder head off since I have nothing to loose. I found that both valves were operating properly, the piston, however, did not move. Since the engine would crank over I would assume I have a broken piston rod, crankshaft, or something in that assembly. I imagine this would be difficult/expensive to replace. Even if I could replace the broken part, isn't it possible that the piston seized up or something to that extent and caused the problem in the first place? I did notice some broken carbon deposits around the piston, I don't think this would be enough to restrict it's movement, however. It's a shame they won't change their oil periodically, then they could avoid problems like this. Perhaps they will learn from this. How difficult would this be to fix? Would I need special tools? I have a feeling this is probably out of my league now but perhaps it's not as difficult as I would imagine. Thanks to both of you for all the help!
post #15 of 24 (permalink) Old 07-21-2008, 05:34 PM
Top Dog
30yearTech's Avatar
A broken connecting rod can be replaced in most cases with standard hand tools. The engine would need to come off of the mower and any drive pulley's removed from the crankshaft, and then the oil sump removed from the crankcase on the engine. This will give you access inside where the connecting rod is. The crankshaft journal where the rod attaches needs to be inspected for possible damage, if the crankshaft is damaged or if there is any other internal damage as a result of the rod breaking, a short block may be in order.
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
