John Deere SX 75 engine question ,,, PLEASE HELP - HobbyTalk
post #1 of 3 (permalink) Old 06-26-2008, 09:48 PM Thread Starter
New Member
Unhappy John Deere SX 75 engine question ,,, PLEASE HELP
Hi , I have a 1988 John deere SX75 w/ a Kawasaki 9 hp engine , it ran fine then it quit getting spark , it has fuel and great compression , but it would start and run a while and quit and not have any spark !!
I replaced the sparp plug , same symptoms , I replaced the coil , same stuff !! The only othe part I can see in the system s a little box called an igniter (that is totally buried , but the mower is in good shape)
What I am wonderinbg is if any one else has had no spark issues with the 9 hp Kaw?? Any sugestions , The igniter costs 63$ , but I see nothing else in the ignition system !! NOTE ,, I did isolate the ignition system on the engine and it acted just the same it would sometimes start and run a couple of minutes and die !!
Thank you in advance for any help on this subject !!
Jeff
jeff927 is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 06-26-2008, 11:31 PM
Member
Most likely its the ignitor you are talking about failing when it gets hot. Only thing you can do is replace it.
phillipmc is offline
post #3 of 3 (permalink) Old 06-27-2008, 12:06 AM
Top Dog
30yearTech's Avatar
Jeff
You can use an after market ignition conversion kit to replace the "igniter" they run around $20.00.
http://www.jackssmallengines.com/sea...at=site_search
30yearTech is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
