air gap between magneto + flyweel - HobbyTalk
post #1 of 9 (permalink) Old 05-13-2008, 09:08 PM Thread Starter
Member
i have a tecumseh HHM80 horizontal shaft engine i am looking for information on how to check the air gap distance from magneto to flyweel it is a internal magneto and i dont know how to get to it with feeler gauges thanks ....chris....
C_Evensen is offline
Sponsored Links
Advertisement
post #2 of 9 (permalink) Old 05-13-2008, 09:33 PM
Elder Statesman
.010 if I remember right
and there is a trick to measuring that, but I cannot recall what it is
pyro_maniac69 is offline
post #3 of 9 (permalink) Old 05-13-2008, 09:39 PM
Elder Statesman
Try using a new business card it will get you close enough. Have a good one. Geo
geogrubb is offline
post #4 of 9 (permalink) Old 05-14-2008, 10:42 AM
Member
"Checking/setting the air gap" does NOT apply to engines with internal magnetos. It only applies to those with external mags. What you are doing when you change the position of the internal mag(coil/stator plate assembly) is change/set the timing of the engine. Refer to the Tecumseh's L-head service manual in the "Ignition" section(pp. 68-69) for a detailed description of the procedure. Keep in mind that you'll need a dial indicator to accurately set the BTDC dimension before moving the coil/stator plate assembly(magneto). In a nutshell, you set the points first(if it has them) then set the piston to the appropriate BTDC position, then loosen the stator plate and rotate it until the points just open.
Having said all that, as a practical matter, unless you suspect someone has changed the setting or removed the stator for some reason, I would look closely at the bolts holding it down. If they are tight and the stator plate doesn't appear to have moved, it's highly likely there is nothing wrong with the current position. If there is no physical interference(stator plate laminations hitting the inside of the flywheel), then it's a matter of deciding whether you think there is a timing problem and hence, a need to mess with it. Again, if those bolts are tight and there's no interference, I'd assume for now the timing is fine and if you are having ignition problems, I'd look elsewhere(ie check for spark with gap tester, replace points/condenser if you have them, check flywheel key etc.)
Bottom line again is the concept of setting the air gap that the previous folks commented on does NOT apply to engines with internal magnetos, only external ones.
dawgpile is offline
post #5 of 9 (permalink) Old 05-14-2008, 10:58 AM
Member
Just a clarification on my previous post. The timing comments only apply to the older engines with points/condensor. If it's not an older one which uses points, and it has an internal magneto, there is no timing adjustment at all, and hence no air gap adjustment. (Same with external magneto engines that have the "solid state ignition". No timing adjustment necessary. Just the air gap setting).
In either case, there is no air gap setting for internal magnetos. Keep us posted!
dawgpile is offline
post #6 of 9 (permalink) Old 05-15-2008, 06:23 AM Thread Starter
Member
thanks for the info dawgpile i downloaded the manual and i see what your talking about the engine is 20+ years old....chris.....
post #7 of 9 (permalink) Old 05-15-2008, 03:31 PM
Member
Cool Threw a Rod
Timing is .090 B.T.C.
Air gap is .012
Point gap is .020
You need a tecumseh dial indicator and a 1/64 scale steel ruler
Pencil and paper...
Tecumseh doesn't mention this because they want their shop to do it....
Set points first at .020 with a slight drag and clean the points with a dollar bill to get rid of any oil or crud.
Set timing next using large treaded screw on dial indicator offset lever for this engine if you don't have dial indicator take off the head and measure very slightly less than 3/32nds (which is .094) before top dead center. I go a little further than .090 to like maybe .100 and move crank clockwise to .090 to take slack out of engine parts.
Disconnect all wires from points and connect a lead from the ohm meter to the threaded point's post and the other lead to ground. When you rotate the crank clockwise to .090 the points should begin to open and the ohm meter should read infinite. If not lossen the stator bolts and rotate the stator to get the points to open at the right B.T.C. settings Then tighten down both stator bolts - Get this as accurate as you can.
This old of a motor like yours requires a tecumseh cut away flywheel to adjust air gap since there is no other way to read the gap between the magnet and coil legs since it's all internal and you can't see it.
Pay close attention this is critical measuring and I found this on the internet form a fellow who helped me with reinstalling loose magnets and how to check north and south poles and I also found how to set the air gap with a piece of electricians tape. Hats off to this fellow I'd be lost without him. Only I went one step futher and figured how to make the air gap adjustment.
The bolts that hold the stator on have a slot that is in a circle rotation Pattern however it has a small amount of up and down movement that's probably moves around maybe a couple of 64ths or so this is where your air gap lies.
First establish a mark on the top stator plate near the top bolt area use a small chisel and lightly tap to make a mark. Do the same for the Bottom stator plate near the bottom bolt area and do the same or use a known point to but your 1/64th scale steel ruler from. Write down all of these locations to help in case you forget.
Second establish a chisel mark to the left of the crank - stator area on the starter housing plate flange lip like where the starter shroud bolt goes into the welded nut take a chisel and mark a area above that nut level across from the top stator bolt then mark a area on the starter housing flange lip level for the lower stator bolt. Then take a very accurate distance measurement from these two marks from the top stator bolt area you marked and "Write it down." This is for in case you happen to go to far and you can return to this measurement.
Do the same for the bottom stator bolt level across to the housing flange where you marked. and write down the distance between these two marks with your steel 1/64 ruler. I repeat write down any adjustment from here on for the top adjustment or bottom adjustment.
Now that you have marked the two spots on the stator and 2 spots on the housing flange. Now your ready to set the air gap.
Use a piece of electricians tape which is .008 to .009 ths. we need .012 Air gap so if we double the tape that's .016 to .018 and that's too thick so I used one strip. When you take the tape off the roll don't streach it cause it affects the thickness. Put this tape over the 3 legs of the coil.
Now very carefully put the flywheel back on straight as you can and not cocked from one side to the other it has to be very straight cause the crank is tapered (I say that cause I had six magnets for a lighting coil and they were spaced 1/4 in apart all around the flywheel.) maybe you just have 2 magnets anyway make sure the flywheel is as far back as it goes to be seated - you don't have to put nut on and torque down. Rotate the flywheel 2 revolutions and very carefully take off the flywheel.
Check the electrical tape and if there is no rubs then we have to set the Air Gap
A- Loosen the top stator bolt and ever so slightly move it to the right say 1/2 of a 64th mayb a slight tap from a hammer will do it - measure that you went that much and write it down! and tighten the top stator bolt.
B- Now loosen the bottom stator bolt and move the same distance and write it down! and tighten down the bottom stator bolt. Doing it this way does not disturb the timing because they both were moved equal distances - (if you move say 1/64 on the bottom instead of 1/2 of a 64th the timing will increase to .100th and thats bad.)
C- With the electricians tape over the 3 coil legs carefully put the flywheel back on and seat then rotate the flyweel 2 revolutions and carefully remove.
Now if you see a very slight drag mark on the electricians tape you have established your air gap. if not repeat the above moving the stator towards the flywheel magnets. After this check your timing again and if off a little loosen bottom stator bolt move stator counter ever so slightly counter clockwise to increase B.T.C. settings or clockwise to decrease B.T.C.
I had a mess when I took my flywheel off 3 magnets knocked loose and bad coil I replaced the coil and fixed the magnets and had spark but when I set the timing and moved the stator I lost the air gap and lost fire. I used this electricians tape and measurement movements on the stator and re-established air gap and was my setting ended up at .092 B.T.C and it's tuff to get it this close because .002th. is finer than frogs hair. With patience and fiddling you'll get it.
I put it all back together and held the coil wire next to the head and give the starter a pull and and there was fire everywhere and with a sharp snap. I must of pulled the starter a dozen times admiring my work like a little kid. I beat the system and so can you.....
If you need more email me at ker.c@hotmail.com like my ole lady says I don't handle defeat to well...
Threw a Rod
P.S. My engine started on first pull hmm.....
Threw a Rod is offline
post #8 of 9 (permalink) Old 05-15-2008, 04:27 PM
Member
Threw a Rod
Air gap is .012
Point gap is .020
Pencil and paper...
Set points first
Set timing next using large treaded screw on dial indicator offset lever for this engine if you don't have dial indicator take off head and measure slightly less than 3/32nds (which is .094) before top dead center. I go a little further than .090 to like maybe .100 and move crank clockwise to .090 to take slack out of engine parts.
This old of a motor like yours requires tecumseh cut away flywheel to adjust air gap since there is no other way to read the gap between the magnet and coil legs since it's all internal and you can't see it.
Pay close attention this is critical measuring and I found this on the internet form a fellow who helped me with reinstalling loose magnets and how to check north and south poles and I also found how to set the air gap with a piece of electricians tape Hats off to this fellow I'd be lost without him. Only I went one step futher and figured how to make the air gap adjustment.
First establish a mark on the top stator plate near the bolt area use a small chisel and lightly tap to make a mark. Do the same for the Bottom stator plate near the bolt area and do the same or use a known point to but your 1/64th scale steel ruler from. Write down all of these locations to help in case you forget.
Second establish a chisel mark to the left of the crank - stator area on the starter housing plate flange lip like where the starter shroud bolt goes into the welded nut take a chisel and mark a area above that nut level across from the top stator bolt then mark a area on the starter housing flange lip for the lower stator bolt. Take a very accurate distance measurement from these two marks and "Write it down." This is for in case you happen to go to far and you can return to this measurement.
Do the same for the bottom stator bolt level across to the housing flange. and write down the distance between these two marks with your steel 1/64 ruler. I repeat write down any adjustment from here on for the top adjustment or bottom adjustment.
Now very carefully put the flywheel back on straight as you can and not cocked from one side to the other has to be very straight cause the crank is tapered (I say that cause I had six magnets for a lighting coil.) maybe you just have 2 magnets anyway make sure the flywheel is as far back as it goes to be seated - you don't have to put nut on and torque down. Rotate the flywheel 2 revolutions and very carefully take off the flywheel.
Check the tape and if there is no rubs then we have to set the Air Gap
A- Lossen the top stator bolt and ever so slightly move it to the right say 1/2 of a 64th mayb a slight tap from a hammer will do it - measure that you went that much and write it down! and tighten the top stator bolt.
B- Now lossen the bottom stator bolt and move the same distance and write it down! and tighten down the bottom stator bolt. Doing it this way does not disturb the timing because it's equal - (if you move say 1/64 on the bottom instead of 1/2 of a 64th the timing will increase to .100th and thats bad.)
C- with the electricians tape over the 3 coil legs carefully put the flywheel back on and seat then rotate the flyweel 2 revolutions and carefully remove.
Now if you see a very slight drag mark on the tape you have established your air gap. if not repeat the above moving the stator towards the flywheel magnets. After this check your timing again and if off a little loosen bottom stator bolt move stator counter clockwise to increase B.T.C. settings or clockwise to decrease B.T.C.
I had a mess when I took my flywheel off 3 magnets knocked loose and bad coil I replaced the coil and fixed the magnets and had spark but when I set the timing and moved the stator I lost the air gap and lost fire. I used this tape and measurement movements on the stator and established air gap and was my setting ended up at .092 B.T.C and it's tuff to get it this close 2thousands is finer than frogs hair.
I put it all back together and held the coil wire next to the head and give the starter a pull and and there was fire everywhere and with a sharp snap. I must of pulled the starter a dozen times admiriing my work like a little kid. I beat the system and so can you.....
Threw a Rod
post #9 of 9 (permalink) Old 05-15-2008, 09:04 PM
Elder Statesman
double post FTL
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
