John Deere E35 Gas Edger - HobbyTalk
Reply
post #1 of 17 (permalink) Old 11-19-2006, 08:57 PM Thread Starter
New Member
Hello Forum
I just purchased a JOHN DEERE E35 GAS EDGER. It's going to be a project. I'm looking for a it's manual. I already googled JOHN DEERE E35 GAS EDGER, and checked out John Deere's web site with no luck. If you have any ideas I would appreciate your help.
Thanks
Drake
dtenorio is offline
Sponsored Links
Advertisement
post #2 of 17 (permalink) Old 11-19-2006, 09:20 PM
Top Dog
30yearTech's Avatar
This unit looks like it may have been manufactured for John Deere by McLane Corporation.
You can look up parts breakdown at the John Deere website
http://jdpc.deere.com/jdpc/servlet/c...ageServlet_Alt
30yearTech is offline
post #3 of 17 (permalink) Old 11-19-2006, 10:54 PM
Member
the e-35 is one of the best edgers made but deere no longer makes it though but
parts will still be around along time so the project should be a winner as for a manual
deere has got pretty stubborn about paper manuals last one i wanted for a tractor was quoted at 75 bones i would look at ebay or find a dealer that would maybe
copy one for you good luck
big ed is offline
post #4 of 17 (permalink) Old 08-15-2008, 07:04 PM
Member
Quote:
Originally Posted by dtenorio View Post
Hello Forum
Thanks
Drake
Hello I'm Norm and I just joined this group. I have a E35 and the edger starts up ok,runs approx 5 minutes and then shuts down. I cleaned the carb. and now have started looking at the spark coil. Not sure if its good as the HV spark cable reads 8.5 k ohms to the metal frame that bolts the coil on the side of the engine. Any idea if that reading is about right? Where should I look how do I fix this .Have you ever heard of this problem. Please advise Thanks Norm
ngwst is offline
post #5 of 17 (permalink) Old 08-15-2008, 10:37 PM
Top Dog
30yearTech's Avatar
Some info off the engine would be helpful to give advice. If you can locate the Brand, Model and Spec numbers off the engine and post back, I am sure someone will have some ideas for you.
post #6 of 17 (permalink) Old 08-18-2008, 05:15 PM
Member
Norm, you should invest in a 'gap type' spark tester. They're inexpensive and available online or at your local auto parts store. This is the easiest way to determine if you have a coil problem(or other electrical problem like kill switch issues). The engine manufacturers typically don't provide specs on things like coil resistance, etc. Nowadays, with components molded into the ignition 'module', you can't necessarily get pure DC resistance measurements, like you can when you are dealing with a just a magneto coil only.
Using the tester, you can see immediately see if you have spark or not. This is one of the fastest ways to determine if your problem is electrical(ignition) or fuel related.
As 30YT mentioned, when you have a chance you should post the engine info and we can provide more targeted feedback. Good luck!
dawgpile is offline
post #7 of 17 (permalink) Old 08-28-2008, 08:29 PM
Member
Quote:
Here are all the numbers listed on the engine. CODE 30D-AS-19. Engine No 056401 T.
That's it. Much appreciated. PS Replaced the gaskets, cleaned carb and fuel tank. Runs much better at start up. At first I thought that the problem was solved,throttled up and down perfectly but died after approx 2 mins. Gas seemed to be coming out under the fuel tank cover. Tried running with tank cover off,tank open but it did the same thing. Thanks again Norm
ngwst is offline
post #8 of 17 (permalink) Old 08-28-2008, 08:32 PM
Member
Will definitely pick one up tomorrow for sure. Thanks Norm
ngwst is offline
post #9 of 17 (permalink) Old 08-30-2008, 02:32 PM
Member
Edit/Delete Message
ngwst is offline
post #10 of 17 (permalink) Old 08-30-2008, 02:43 PM
Top Dog
30yearTech's Avatar
Quote:
What are you calling the fuel tank cover? The cap where you fill the tank up?
post #11 of 17 (permalink) Old 08-30-2008, 06:12 PM
Member
Yes I;m referring to the cap that has to be removed in order to fill the gas tank.Thanks Norm
ngwst is offline
post #12 of 17 (permalink) Old 08-31-2008, 12:19 PM
Member
Purchased spark tester and problem seems to be fuel related. Spark normal and does not drop off or go away. Dismantled carb once more and cant find anything that's clogged Any idea how to find a replacement carb? Much appreciated. Norm
ngwst is offline
post #13 of 17 (permalink) Old 08-31-2008, 01:23 PM
Top Dog
30yearTech's Avatar
http://www.jackssmallengines.com/sea...12&sa.y=11#204
post #14 of 17 (permalink) Old 08-31-2008, 07:37 PM
Member
Sorry but I made an error in the engine information supplied earlier. The correct info is Code FA130D-AS-19 and the other number is 056401 T Thanks Norm
ngwst is offline
post #15 of 17 (permalink) Old 07-18-2009, 05:33 PM
New Member
JD E35 Edger - The greatest
Corner lot in the city with about 650 feet of edging to do every week. Stick type edgers are hard on my back - pushing 70 yrs.
Looked at dozens of new and used edgers. Finally found this very used JD E35. It barely ran and stalled with the belt tension. I was so impressed with the rugged construction so I bought it anyway. $125 for a machine that cost 700 new. Why not.
With the help of a neighbor, a can of carb cleaner and a screw driver it now purrs like a kitten.
What a machine! Edging is now a pleasure. As a bonus I discovered it will drop down the right rear wheel and do curbs perfectly.
They don't make them anymore because the factory burned. What a shame.
Walt
walt s is offline
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
